Old 11-26-2011, 09:56 PM
iachaser iachaser is offline
06 Silverado Passenger Side Power Window Issue
Long time lurker, 1st time poster here...
Got a friend who has a 06 Silverado 2500 crew cab.He has power windows/locks. One day both of his passenger side power windows stopped working with no warning or symptoms. I've done some initial troubleshooting and have found the following:
The power locks and lights on both affected doors work just fine.
There is NO power to the window motors on either door.
The passenger side windows do not work from the driver's door switch or the switch on the affected door.
His driver's side windows work just fine.
I know the switches have a high failure rate on these vehicles... Looking for ideas on what to check next or whether or not to replace the driver's door switch panel. They're pretty pricey, so thought I'd ask for some help on this one..
Thanks in advance,
Mike
The Following User Says Thank You to iachaser For This Useful Post:
cf1 (11-27-2011)
Old 11-27-2011, 03:38 PM
cf1 cf1 is offline
Re: 06 Silverado Passenger Side Power Window Issue
Thanks in advance,
Mike
Its usuly the motor jump the switch and see if the window works.
Old 11-27-2011, 05:06 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
There is a ckt. breaker in the IP fuse block for the Rt doors, check for power there, if no, check under hood fuses for blown, especially the MBEC 50amp fuse.
How do you replace the passenger side power window motor pint4 M Bodies 4 06-25-2007 06:03 PM
Caravan 2000-Passenger side power window. Bacoman Caravan | Voyager 3 08-08-2005 10:07 PM
Passenger Side Power Windows :[ AidenFox Grand Cherokee | Grand Cherokee SRT8 5 05-21-2005 05:21 AM
Passenger side power window motor replacement? Help!!! Cogtx Windstar 8 02-17-2005 10:55 PM
1999 Grand Cherokee problems with passenger side power windows, locks, mirror mklein Grand Cherokee | Grand Cherokee SRT8 9 07-03-2004 06:10 PM
