Old 11-25-2011, 04:37 PM
ia31638 ia31638 is offline
97 blazer fuel pump
Two issues. Fisrt issue po305 misfire #5. Second issue fuel pump not holding pressure. Turn key on jumps to about 62 when pump is priming. When pump stops drops to zero immedialty. Its does start but takes quite a bit of cranking. Seems to run fine about 50-60psi while running. Also had a po300 last week. 138000 miles. Seperate issues or related?
Old 11-29-2011, 07:39 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
Re: 97 blazer fuel pump
When was the last time you replaced your Distributor Cap? If your cap is old and/or not an AC Delco, you might try replacing your cap and Rotor. A bad cap will throw all kinds of codes.
Sounds like your Fuel Pump is going bad. When was the last time you changed your fuel filter? If you have good pressure, it should crank and run.
The fuel filter, new or not, will not cause the pressure drop, however, a new fuel filter might help if not enough fuel is getting through the old filter.
"If everyone is thinking alike, then no one is thinking". - Gen. George S. Patton Jr.
Old 11-29-2011, 08:47 PM
new cap,rotor,wires,plugs going in tommorrow. All are ac/delco. New fuel filter last week. How and where are people plugging or pinching the return fuel line too see if its the fuel pump or fuel pressue regulator not holding pressure? Blazer will run if cranked long enough.
Old 12-01-2011, 06:21 PM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
Thanks to write-up Old_master e-mailed me, I made a gauge to check the pump pressure.
The gauge was made with parts readily available from Napa and Ace Hardware.
Napa 730-5013 steel fuel line repair fitting, 3/8"
1 ft 3/8" hose, 2 clamps.
Ace - 3/8" ball valve
3/8" male to barb fitting (for the hose attachment)
3/8+ male/female adaptor (because the steel tube hit the ball of the valve)
Old Master's parts were somewhat different, but close to the valve (lower unit in the picture above). I clamped the open end of the hose onto the output of the fuel filter, and steel tube into the pipe to the injectors.
Once the fuel pump primed, I shut the valve as soon as the pump stopped.
Pressure gauge registered 52 psi steadily,indicating a good pressure regulator. As soon as the valve was opened, the gas went back thru the pump, and pressure went to 0 immediately. There was a small hole in the fuel pump line to fuel pump assembly top cover.
It's my opinion, don't take it personal.
'04 T&C,'01 Blazer ZR2, '97 Blazer, '97 Sunfire, '85 Vette, '79 Civic, 94 FLSTC
Old 12-01-2011, 07:34 PM
Tech II Tech II is offline
Mike's setup is the same thing GM has, except it has fittings on both ends.....you just disconnect the outlet of the fuel filter and attach the shutoff valve.......can install this in the same area on the return line to check the regulator and injectors.....
As for the misfire, it could be secondary ignition or the injector.....
Old 12-02-2011, 09:48 PM
Thanks for the info guys. I had a double whammy, fuel pump was leaking down, and #5 injector was leaking. Got them both replaced and all is good now.
96 Blazer 4x4 2 door fuel pump marinesemperfi Problem Diagnosis 10 05-22-2009 10:56 PM
PROBLEM now 98 blazer 4.3 v6 just replaced fuel pump smiley24 Problem Diagnosis 7 02-26-2009 10:45 AM
1996 chevy blazer fuel pump clark123 Blazer 0 07-15-2004 08:07 PM
97 s-10 blazer fuel pump DoubleDeezy Blazer 3 07-15-2004 05:12 PM
94 s10 blazer fuel pump relay location ihatemyblazer Blazer 2 04-20-2004 08:53 AM
