Go Back   Automotive Forums Car Chat > Buick > Regal
Old 11-22-2011, 08:53 PM
Cmal Cmal is offline
Shaking at Idle
Alright, so I've got a 95 Regal GS 3.8 liter V6. She started getting a little hot at idle so I changed the thermostat and burped the system and she hasn't run hot since. However she has started idling really rough to the point the car kinda shakes. She accelerates fine, drives smooth, and if I keep a foot on the gas and keep her over 1000 rpms the shaking stops. I'm pretty sure I got all of the air out of the system, but the very top of the bleed screw did break off the thermostat housing somehow. Also, the car has had an electrical issue for quite some time, the fuel pump was replaced about 2 years ago, the MAF sensor about a year and a half ago. Anyone have any ideas before I get the chance to get the codes? I was thinking plugs/wires, bad coil, bad motor mount or vacuum leak, but the problem started right after changing the thermostat, which makes me think that had something to do with it. Thanks in advance!
Old 11-23-2011, 09:25 AM
Tech II Tech II is offline
Re: Shaking at Idle
Lots of places have problems reading codes for that year....
Mileage? Last tuneup? Losing coolant? Is upper plenum, black plastic?
Old 11-24-2011, 10:31 PM
Re: Shaking at Idle
142,000 miles, last tune-up about 8,000 miles ago, yes, upper plenum is black plastic.
Old 11-25-2011, 03:07 PM
Re: Shaking at Idle
Check fuel pressure.....
See if vehicle runs better with MAF sensor disconnected....
Check vac to F/P regulator for gas......
Check spark output with a spark tester.....
If you are losing coolant and see no external leaks, could be burning it up in cylinders due to a leaking upper plenum.....
Old 11-26-2011, 07:49 AM
big white bufflo big white bufflo is offline
Re: Shaking at Idle
check for any vac leaks in the area you were working you could have broken some or nocked one off what the guy are taking about the upper plenum the 3800 are prone to melt around the egr port if you take the throtle body off you will see a tube sticking up in the manfold look aroung that if you smell coolant out the exhust
Clio 1.2 16v 2002 Expression idle problem!! stuuuu Clio/Clio II/Clio III 1 05-03-2010 02:59 PM
low rmp idle idles rough lilrebel C/K 4 11-24-2007 12:40 AM
Wobble Wobble Shake Shake Down The Road I Go brittce Taurus | Taurus Wagon 9 03-23-2005 06:51 AM
Shaking Idling and up to 2000 Rpm 240sxMN Camry/Camry Hybrid/Vista 4 11-15-2004 03:38 PM
Shake Shake Slacky Tires and Wheels 6 02-05-2004 08:12 PM
