Go Back   Automotive Forums Car Chat > Buick > Regal
Old 11-19-2011, 10:52 PM
GMan0820 GMan0820 is offline
oil spraying from the oil filter
I have a 1998 Buick Regal LS with a 3.8 ltr engine. i started the car to warm it up the other day and when i returned found a puddle of oil under the car. The oil was spraying from the oil filter. I changed the filter making sure there were no old gaskets. started the car and the same thing happened. I changed the pcv valve and filter again and same problem. it seems like the oil is going into the filter and not returning to the engine. Any ideas?
Old 11-19-2011, 11:30 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: oil spraying from the oil filter
You might have a stuck or plugged oil pressure relief valve, so your pump is building excess pressure, which can rupture the filter.
It should be built-in to your oil pump
Try hooking up an external oil pressure gauge. If the pressure goes much above 60 psi, there's your problem.
smoking from the oil filler cap, dipstick and exhaust jimgbgt MGB 2 07-24-2009 04:26 AM
Oil getting in the air filter BuzzV59 Grand Cherokee | Grand Cherokee SRT8 2 01-12-2006 11:12 AM
oil leack from the carburettor aiwa2005 Golf 1 10-02-2005 02:12 PM
