Go Back   Automotive Forums Car Chat > Cadillac > CTS and CTS-V
Old 11-18-2011, 12:19 PM
mr_hops48 mr_hops48 is offline
2003 cts
i have a friend with a 2003 cts. he states that he is finding oil in the radiator.
is this the normal , head, head gasket or manifold gasket type of issue? or is there something else to look at on this model
thanks
jim
Old 11-18-2011, 06:59 PM
maxwedge maxwedge is offline
A990 racer
Re: 2003 cts
No oil is normal in the rad. is it trans fluid or engine oil?
Old 11-18-2011, 08:09 PM
Re: 2003 cts
i didn't mean oil was normal. i meant normally that if oil is in the radiator it's a head / manifold gasket or head problem.
i believe he said regular oil (not trans fluid)
Old 11-19-2011, 08:07 AM
A990 racer
Re: 2003 cts
Normally that could be a bad cooler in the radiator if it is trans fluid, if oil that could anything where an intermix can occur, such as a cracked block, head or internal gaskets.
Old 11-19-2011, 09:53 AM
Re: 2003 cts
i dont believe that there is any coolant in the oil pan. i thought that when the head problems appeard, the flow was the other way. (coolant in oil, not oil in coolant) was wondering if the was anything special about this vehicle that would cause the flow to be opposite. since the coolant is pressurized it would seem that the flow would always be water to oil.
thanks for answering
Old 11-19-2011, 12:58 PM
A990 racer
Re: 2003 cts
When shut off and no pressure a bad gasket where oil and coolant passages run near each other, the oil could get into the coolant, the system should be pressure tested and a sample of the contaminated coolant lab tested for an analysis of the content. I would do a google search for any TSB's or tech info on the year and engine CTS in question.
The Following User Says Thank You to maxwedge For This Useful Post:
mr_hops48 (11-20-2011)
Old 11-20-2011, 06:56 AM
Re: 2003 cts
actually found another link on google relating to this problem
looks like it may be a bad oil cooler that is located between the heads.
2003 cts PawnofChaos CTS and CTS-V 2 02-28-2010 09:28 AM
Silverado 2003 CTS (coolant Temp Sensor) andreval Silverado 5 07-20-2008 10:00 PM
2003 CTS Code P2176? demo_deven CTS and CTS-V 2 07-08-2008 01:04 PM
2003 bmw m3 vs 04 cadillac cts-v youngvr4 Car Comparisons 61 05-10-2004 11:52 AM
