Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 11-17-2011, 08:15 AM
rm54 rm54 is offline
Question PO453 Code
Hi,
1999 Jimmy
I had my "servive engine soon" light come on. I took it to a mechanic to diagnose and he said the fuel tank pressure sensor was bad. They did a complete diagnostic, not with just a hand held scanner. They recommended that I replace the whole fuel pump because it has a bad check valve. I just had it replaced about 4 years ago. The fuel pump is working fine and all I want is the SES light to go off. I plan on doing this project myself so what I want to know is should I replace a 4 year old pump or will just replacing the pressure sensor make the light go out? Thank you
Old 11-17-2011, 10:44 AM
maxwedge maxwedge is offline
A990 racer
Re: PO453 Code
What does the fp have to do with the cel/sensor? If you feel while you are in there it should be done, different story.
Old 11-17-2011, 07:05 PM
FishFind FishFind is offline
One Hot Shot
Re: PO453 Code
is the sensor bad?
l
You also have vent lines that can get clogged or pinched. If you need to drop the tank to do this then I would think about doing the pump as well. Or you could leave the light on. Doing the pump is a lot of work and money just to clear a code,
code 24 zetan Corolla/Matrix/Voltz 2 04-10-2009 09:59 AM
SES code help redfox3369 Venture 1 04-09-2009 12:42 PM
trouble codes danielgast46 F Series 6 04-06-2009 07:06 AM
1993 Acura integra Stereo Code Omega-Factor Interior | Audio | Security 1 03-25-2009 07:08 PM
01 Sport Trac Door Code??? levi.calhoun Explorer | Explorer Sport Trac 1 03-23-2009 10:09 PM
