95 Windstar Rear Brakes
Hey guys, been a while since I've over here so I thought I'd stop by for a little advice. I'm going to need to do the rear brakes on my 95 I'm fairly sure since the parking brakes won't hold it even on a slight incline. I've never had the rear drums off of it but I've been told that the self adjusters give trouble on these. They sell the kits for them, I'm just wondering if it's something I should go ahead and order when I get the shoes.
1995 Windstar 3.8L 2001 Dodge Ram 2500 5.9L Gas Burner 1986 VW Golf 1.6L Diesel |
Re: 95 Windstar Rear Brakes
While I don't want to assume anything, are you saying the brakes haven't been done by you and the van was bought used or the drums haven't ever been off?
Brakes are one of those jobs where you can replace only shoes and springs, right up to a full overhaul, where everything is replaced. I used to try and cheap out a bit but when I'm working lately I'd rather replace more than less and know it's all good for a year or so. If that's the tact you take, I'd do the wheel cylinders, cable to the E brake, shoes, drums, spring kit, self adjusters, full bleed. Working with new components is so much better than fiddling with old stuff that is only going to need replacement sooner than later. fwiw my
----------- 2000 windstar 3.8 2010 honda pilot touring Muskoka Canada |
hey, I totally hear you on the money thing... believe me. If the wheel cylinders are good, no leaks, and both sides of the piston are moving, don't replace them. If you start to take them apart, for sure you're going to need a rigid line or 2 as they have been on so long. My best advice is to spray the bleeders with some pb blaster a few days before you want to start the job, and each day until. That'll loosen them up. The spring kit, shoes and drums aren't that much money so the job won't be crazy pricy. I've never replace my self adjusters tho I bought them the first time thinking I would need to. They seem to last quite a while. You'll need some anti-seize compound too, and some brake fluid. I'd bet the whole job could be done for $150.
The link in my signature takes you to a folder of pictures of many projects that I did on my '96 windstar.
I have a series of pictures that show the rear brake job. I also have a couple of pictures that show the wheel cylinder replacement. The wheel cylinder pictures are much later in the pictures because they were done years later than the rear brake job. The hardest thing in replacing the wheel cylinder is the brake line connection to it. The nut seems to corrode to the hard brake line....and the whole thing turns when you turn the nut. On 1 I removed the wheel cylinder, except for the brake line....and used a wrench on the nut and turned the wheel cylinder, not the nut. After a lot of working it that way, the nut finally worked free from the hard line.
Moderator for Ford Windstar room only Links to my pictures, intended as an aid, not a replacement for, a good repair manual. 1996 3.8L Windstar http://www.flickr.com/photos/4157486...092975/detail/ 2003 Toyota Sienna pictures (not much there yet) http://www.flickr.com/photos/4157486...781661/detail/ |
I would recommend a new thread for the new problem.
I have some pictures of the steering column with the covers off from when I replaced the multifunction switch (turn signal). I don't know if it shows anything of much help to you except how to get that far.....so you can see the ignition cylinder, linkage and ignition switch.
| The Following User Says Thank You to wiswind For This Useful Post: | ||
uzzo2 (11-20-2011)
