Go Back   Automotive Forums Car Chat > Saturn > LS/LW
Old 11-08-2011, 02:52 PM
mxmissle mxmissle is offline
2001 Saturn LS200 Brake fluid leak and fuel smell
On the front of the firewall, the two brake lines go to the rear of the car, there are 2 "AA battery-sized" fittings on the car. One of them is leaking, a lot. What are these fittings called, where can I get them, and if I can't, can I just run new brake lines without them?
Also, I have a strong fuel smell, and I can't figure out where it's coming from. Any ideas or typical places that fail on this car?
Thank you in advance
Old 11-08-2011, 04:24 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 2001 Saturn LS200 Brake fluid leak and fuel smell
I believe the parts you are describing are the rear brake proportioning valves. I imagine any parts store would carry them, or could get them. You do not want to bypass them as they are used to help reduce rear wheel lock up.
As for the fuel smell, inspect all fuel lines and connections for leaks or evidence of leaks.
Old 11-08-2011, 11:45 PM
Thank you for the help. It led me down the right path to find out that they're called residual pressure valves. I'm calling Wilwood tomorrow to check application and part number before I order. I'll post the part number here in case it helps anyone else. http://www.wilwood.com/MasterCylinde...derValves.aspx
SSBC also makes them, but that looks just like the one that failed
http://www.ssbrakes.com/commerce/det....cfm?nPID=8866
As far as the fuel leak, I'm stumped. I've been over that car several times...Looks like it's time to "Call the guy". That's why professional technicians are professionals. Thanks for the help.
2000 Windstar transmission fluid leak olopezm Windstar 16 09-17-2010 08:51 PM
fuel smell in car and stalls sometimes? HELP mark4674 Taurus | Taurus Wagon 0 12-19-2009 07:08 PM
Brake fluid leak john3mo Lumina 3 11-16-2009 03:28 PM
2001 I30 Rear Brake Fluid Leak larry0 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 0 05-26-2006 10:30 PM
