Old 11-07-2011, 05:35 PM
joslinm joslinm is offline
98 S-10 starting
4 cyl,
Sits in the driveway for a month during the summer and starts right up. Try it again a few days later and it barely fires and the battery just about runs down before I can get it going.
Where to start. Runs perfect otherwise.
No codes
Anything you'd try?
Old 11-07-2011, 06:55 PM
FishFind FishFind is offline
One Hot Shot
Re: 98 S-10 starting
Test that battery. I had that happen to me before. It would actually make my truck stall when driving. My battery had a bad cell
Old 11-08-2011, 01:40 PM
it's had a new battery since this all started
Old 11-08-2011, 04:10 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
So, whats happens with the new battery installed? Still a crank, no start?
Old 11-08-2011, 05:07 PM
It's very intermittent.
It's like the wires are wet even though they're not.
Usually starts fine, but every now and then for no apparent reason, it just barely fires on 1 cylinder and then eventually starts
Old 11-08-2011, 06:16 PM
gmtech1's Avatar
You need to check fuel pressure and spark when it's acting up.
Old 11-10-2011, 06:13 PM
j cAT j cAT is offline
starter operation is normal but engine does not run.
fuel pressure testing also plug wires/distributor cap/rotor connectors to it need cheecking out. plug wires need be ohm tested if out of spec and wires look hard cracked miss routed melted replace. plug wires need proper fastening as built. 1998 vehicle these plastic holders fail causing the plug wires to get damaged.
place some dieelectric grease in the plug wire boot ends to prevent new wires from damage..this also helps when removing them.
hard start rjinmt F Series 1 01-07-2012 01:05 PM
