Old 11-05-2011, 03:18 PM
Cruize Cruize is offline
'95 Encoder Motor
'95 w/ NP233 transfer case
My transfer case will shift between 2hi and 4low, but not 4hi.
The shop manual troubleshooting sections says to replace the encoder motor.
Is there any way to fix the old motor?
Cruize
1992 Ford Escort GT, 5-speed - Now with an unlimited slip clutch! :sarcasm1:
1995 Blazer LS, 4x4, 4 door
1996 Pontiac Grand Am GT, 5-speed
1997 Suzuki DR650 ~54 mpg
Old 11-05-2011, 11:22 PM
FishFind FishFind is offline
One Hot Shot
Re: '95 Encoder Motor
No idea but if you need to replace for that old of a car I would get one from a junk yard. They are not cheap.
Old 11-13-2011, 10:22 PM
Front Drive Shaft / Encoder Motor Removal
'95 Blazer 4 door w/ NP233 T-case
I have all the bolts out of the encoder motor, but can't get it out without removing the front drive shaft. I removed the four bolts from the yoke(?) at the front axle input shaft. How do I remove the drive shaft? Do I need to compress it somehow?
Thanks in advance.
Cruize
Old 11-15-2011, 06:32 PM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
Re: Front Drive Shaft / Encoder Motor Removal
With the bolts from the clamps removed, get a good grip on the shaft and push/slide it back towards the transfer case. Twisting/turning the shaft as you push it back helps. Once it moves back, you can drop it down from the yoke carrier, then pull it forward out of the transfer case.
It's my opinion, don't take it personal.
'04 T&C,'01 Blazer ZR2, '97 Blazer, '97 Sunfire, '85 Vette, '79 Civic, 94 FLSTC
Old 11-19-2011, 04:31 PM
exalteduser's Avatar
exalteduser exalteduser is offline
Goober
And when you do that grease will ooze out fair warning!!
1991 Jeep Wrangler 4.0 (3rd child or 2nd wife)
1999 Chevy Suburban 1500 5.7
2005 Toyota Rav4
1994 S-10 Blazer 4.3L "W" "Dead and gone"
Old 11-27-2011, 09:31 PM
Thanks for the info.
The transfer case wouldn't shift into low range any more. It turns out the contacts for 4Lo in the pushbutton switch were mangled and constantly touching. I separated the contacts and voila - normal transfer case operation!!!!
Cruize
Taking Off 4x4 Encoder Motor MJTrippy Blazer 4 01-05-2005 02:29 PM
Encoder motor (transmission) RoboProp Blazer 0 07-14-2004 02:10 PM
'99 Encoder Motor Oznavad Yukon 1 12-14-2003 09:30 PM
95 Blazer Encoder motor for 4WD rcarh Blazer 0 11-29-2003 11:39 PM
Tahoe - Encoder Motor leerider C/K 0 08-14-2003 01:37 PM
