Go Back   Automotive Forums Car Chat > Dodge > General Discussion
Old 11-03-2011, 02:14 AM
RAINBOW4 RAINBOW4 is offline
Automatic Transmission in Dodge truck does not shift
My Dodge truck does not shift correctly. It will tach high and sometimes I have to put in neutral to et it to shift. The rpms are high when it shifts. I replaced the transmission but problem still there.Help!
Old 11-05-2011, 12:56 AM
trannyman52 trannyman52 is offline
Re: Automatic Transmission in Dodge truck does not shift
would suggest a Superior brand or Transgo shift kit ,,,,,does wonders for that trans,,,don't forget to remove check valve in cooler line,,that will help it from trashing the OD in the trans.......
Old 02-26-2012, 01:05 AM
gympy_d gympy_d is offline
Is your kickdown hooked up and functioning correctly? If not it won't shift properly and will fry the transmission!!! Kickdown must be connected on Chrysler transmissions unless you have a manual shift valve body, and it must also be set correctly or it will not shift
Old 02-26-2012, 07:25 PM
jamesslcx jamesslcx is offline
Rainbow, all good advice so far. What year is your truck? Did your other tranny do the same thing? Check engine light on?
96 Dodge Van 3500 Automatic Transmission Failure vince2010 Ram Van 7 01-14-2013 03:12 AM
97 SL2 Automatic Trans, will not shift into overdrive lotsoffear SC/SL/SW 0 10-05-2010 09:35 PM
01 Civic Automatic Transmission Shifts like...? Shrewz92 '01-'05 Civic 9 08-15-2010 02:45 PM
Auto Trans not shifting Fontenot74 Mustang Problem Diagnosis 2 03-04-2009 08:30 PM
transmission does not shift gears eteguay Caravan | Voyager 3 02-18-2006 11:34 PM
