Old 11-02-2011, 10:52 PM
Andrew1941 Andrew1941 is offline
2001 Windstar Door locks not opening
2001 windstar with electric door loocks; locks not opening on any doors with FOB EXCEPT drivers door (it works fine). Using the electronic switch inside the drivers door results in same as using FOB (drivers door only). Only way to locks other doors is manually.
I have not checked through the fuse panel yet but was planning on looking shortly because it seems like a fuse thing. I searched around forumn but found nothing on this. Any one seen this before?
2001 3.8L V8 Deathstar with 170,000 KM
2010 GMC Sierra 1500 Crew with 2500 KM
Old 11-03-2011, 09:51 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: 2001 Windstar Door locks not opening
If checking the fuses shows no results, the next thing would be to check the connections at the REM (Rear Electronics Module). This device handles the rear A/C controls, rear lights and power door locks. It is located at the rear passenger side quarter panel, by the jack and the Inertia Switch. I know some users didn't remove the quarter panel and instead only removed the covering material.
The drivers door lock is controlled by the FEM (front EM) and that's why it's still working.
In case you end up having to replace it make sure you get one from a windstar with the same trim level as yours, if you don't you'll need to have it reprogrammed at the dealer in order to make it work in your minivan.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 11-07-2011, 09:56 AM
mark_gober mark_gober is offline
Do you hear any noise coming from the non-functioning locks. Ford is notorious for the construction of P.O.S. window motors and door lock actuators. I realize that it would be a stretch to think that all your lock actuators stopped functioning at once, but if you hear a noise (typically a rattling or buzzing noise), it would indicate that the circuitry is functioning.
Mark
2000 Windstar Door Lock Actuator jackaa Windstar 1 10-25-2008 10:42 PM
2001 Maxima rear door will not open from inside or outside rwig Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 08-30-2004 08:34 AM
96 windstar door locks going nuts buzzsawh Windstar 2 07-18-2004 02:03 AM
Remote control front door locks won't open pizzaman2004 LeSabre 1 05-29-2004 09:33 PM
