Old 11-02-2011, 11:16 AM
comet240 comet240 is offline
96 voyager 33 engine AC pump bolt sheared off again grade 8
hi i had the bolt shear off that holds the AC compressor to the engine its the one facing the fan, the other bolt that at top from the side of engine is fine and the other bolt that bolts to the water pump housing been gone long time, but the one in front i had to drill out and i put a grade 8 bolt in 11/6 socket head now the grade 8 bolt has sheared off what the hell what grade u need to put in that it cant shear off i had put a lock washer on too so it wouldnt come loose yet it busted off now not sure if i can drill this out i had lock tight on it i think
so whats the cure how u fix this problem so it wotn happen again?
Old 11-16-2011, 05:16 PM
Cntrysthbst Cntrysthbst is offline
Send a message via Yahoo to Cntrysthbst
Re: 96 voyager 33 engine AC pump bolt sheared off again grade 8
i have never had luck buying bolts from hardware stores no matter what grade. you can go to the dealer and buy the bolts and be broke or go to the junkyard and get them. i have a over tightening problem and probably would help to use a torque wrench, and lock-tight, and tighten it to specs. i don't know if its just me but i think bolts were made better back in the days. so i would look into a junkyard, and they are on-line too. some probably don't agree with this but it has worked for me.
Old 11-29-2011, 07:01 AM
b1lk1 b1lk1 is offline
Buy a bracket and the bolts from the junkyard. Replace the bracket and use a torque wrench. You are over-tightening the bolts. They don't need to be tightened as much as humanly possible and although I don't know the exact specs, 75 ft-lbs would be more than enough.
Old 11-30-2011, 05:43 AM
ah ok i got another bolt from Canadian Tire as junkers couldnt help me they dont keep any car more then 10 yrs old so i lucked out on the 96 but i bought another grade 8 put blue lock tight on it and this time no lock washer and i just tightend to where i thought it was tight but i guess also u cant drill out a grade 8 bolt only use gas axe to cut it out even then was hard to do in spot it was ugh
Camshaft gear pin sheared off 2000 Corrola, other problem. mikmic2 Prism 0 06-18-2007 05:04 PM
Camshaft gear pin sheared off 2000 Corrola, other problem. mikmic2 Corolla/Matrix/Voltz 0 06-18-2007 05:03 PM
1998 and 1999 Windstar sheared off lug nut studs krewl1 Windstar 7 09-30-2005 07:49 AM
wheel on odyssey sheared off gigglesnirt Other Motorsports 1 04-26-2004 12:58 PM
Head problems - Pin in Vtec rocker arm Sheared off 5_LiTeR_EaTeR Engineering/ Technical 0 07-18-2002 11:47 PM
