Old 11-02-2011, 09:16 AM
mno221 mno221 is offline
inter tie rod
How hard is it to change out the inter tie rods on a 2001 silverado 5.3 2w.
Is it a DIY job. I'm pretty handy with tools.
Old 11-02-2011, 04:24 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: inter tie rod
First price out a rebuilt rack and pion with ties rods on it against just the tie rods.
About 2 hrs labor to change inner tie rod ends.
MT
The Following User Says Thank You to MT-2500 For This Useful Post:
mno221 (11-03-2011)
Old 11-03-2011, 09:12 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: inter tie rod
Depending on how rusted/fused together they are with the outer rods (, you might make it easier on yourself and replace the inners and outers as a set. Then you only need to match the lengths and not waste time beating them loose to get them unscrewed.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
The Following User Says Thank You to jdmccright For This Useful Post:
mno221 (11-03-2011)
Old 11-03-2011, 12:54 PM
j cAT j cAT is offline
Re: inter tie rod
if you do not have a rack steering system this is no that difficult. the inner tie rod requires medium lock tight on the thread and to be torqued to about 70 ft lbs.
the tie rod inners fail because GM used a defective part to retain the rubber grease seal. using tie raps/plastic tie straps to seacure the rubber is long lasting and prevents wear/rust /grease loss.
you will need a big open end wrench about 1 5/16 in or so.
The Following User Says Thank You to j cAT For This Useful Post:
mno221 (11-03-2011)
ball joint or tie-rod end? thinmint Dakota 1 03-07-2010 10:39 PM
ball joint? tie rod? HELP! cjedstrom Cougar 2 11-26-2009 05:53 PM
how to change tie rods? JohnVT Cirrus 3 04-05-2009 10:32 AM
Tie Rod Assembly Part # Philosopher Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 2 07-17-2001 04:50 PM
Tie Rods Chainsaw Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 0 06-22-2001 04:03 PM
