Old 10-30-2011, 05:38 PM
toddomen toddomen is offline
Coolant leak
I have a 2006 Pontiac Grand Prix with 91,000 miles. I have a small coolant leak just past the front passenger side tire. Are water pumps known to go bad in these cars? Is there a way I can check the water pump to see if its bad?
Old 10-30-2011, 07:09 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: Coolant leak
I've replaced a couple in my '97 GP but I guess it depends on which bran you choose for replacement.
All water pumps have a bleed hole with a seal just behind the pulley, when the seal goes bad coolant starts to leak through the bleed hole indicating the pump needs to be replaced. You'll need to take a close look at it in order to find out where the coolant is coming from.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 10-30-2011, 09:33 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Coolant leak
The area you are describing sounds like water pump. If you have a inspection mirror you can use it to look under/ behind the water pump pully for a leak. Also check all hose clamps and around the intake gasket. If this has the belt tensioner that runs the heater hoses it, check the fittings in that also.
Old 10-31-2011, 10:56 AM
GMCustomerService's Avatar
GMCustomerService GMCustomerService is offline
Re: Coolant leak
If you would like for me to look into any open recalls on your specific vehicle, I’m happy to! Direct message me with your name and last 8 digits of your VIN and I’ll look into it!
Thanks,
Sarah
GM Customer Service
Old 10-31-2011, 04:25 PM
Tech II Tech II is offline
Re: Coolant leak
Agree with GM tech1....in addition to checking the weep hole on the w/p, check those plastic elbows to the tensioner assembly......
'94 3800TS: power steering and coolant leaks jarl Trans Sport 1 08-03-2010 04:02 PM
'94 TS 3800: HUGE coolant leak - and other fluids jarl Trans Sport 23 10-31-2009 07:53 AM
2001 Chevy Cavalier Coolant System Problem getwilde Cavalier Problem Diagnosis 0 09-18-2009 06:43 PM
2000 Blazer lower intake plenum coolant leak Sedatedbylife Problem Diagnosis 8 06-27-2009 10:20 PM
98 Grand Caravan 3.3L Coolant Leak hooperkj Caravan | Voyager 4 04-22-2009 04:17 PM
