Go Back   Automotive Forums Car Chat > Buick > Skylark
Old 10-30-2011, 09:33 AM
John1397 John1397 is offline
1981 Buick ECM
I have a 1981 Buick Skylark V-6 with an ECM 1224810 CO and I got a replacement ECM 1224810 FX from a 1981 Omega 4 cylinder what do I need to watch for?
John
Old 10-30-2011, 02:42 PM
maxwedge maxwedge is offline
A990 racer
Re: 1981 Buick ECM
You can watch for it most likely not to work, 4 vs 6?
Old 10-31-2011, 06:31 PM
Re: 1981 Buick ECM
As far as I can tell both units are the same as it runs fine and is rich on idle and lean on high speed.
John
Old 10-31-2011, 06:56 PM
A990 racer
Re: 1981 Buick ECM
The same but is has the the wrong fuel curve?, so now what, they are not caibrated the same, no?
Old 10-31-2011, 07:12 PM
Re: 1981 Buick ECM
Could be, but at least it runs leaner at high speed than if you have no computer at all this should save fuel as far as timing I have no idea what it actually does.
John
Old 11-01-2011, 12:19 PM
Tech II Tech II is offline
Re: 1981 Buick ECM
If the ECM number is same, should be able to use it....just have to transfer the PROM, or in some cases, there may be a knock sensor "module" also to transfer......
1981 Camaro for sale lolaz28 Sell / For Sale 0 07-12-2009 12:57 AM
error or trouble codes 93 buick lesabre custom thecone_99 LeSabre 9 03-03-2009 06:49 AM
Which is the ultimate Buick: the 1987 Buick GNX or the 1970 Buick GSX Stage 1? Musclecarclub Engineering/ Technical 41 05-28-2007 10:01 PM
3.8 buick park ave buick wanting to die Dsmith362003 LeSabre 3 12-22-2004 12:02 AM
Which is the ultimate Buick: the 1987 Buick GNX or the 1970 Buick GSX? Musclecarclub Engineering/ Technical 0 02-11-2004 02:30 AM
