Old 10-29-2011, 01:55 PM
horse482's Avatar
horse482 horse482 is offline
AF -Advisor
'94 K1500 Transfer case ?
I have a 94 K1500, 5.7l, NV4500 trans, & NP241 transfer case. I am transferring oil from the transfer case to the transmission. I was told that the input/output seal is bad, but it was just changed 25,000 miles ago. Is it possible that I just have a breather plugged and that it causing to much pressure in the transfer case forcing the oil in to the trans? Or am I going to be pulling the transfer case again and replacing the seal?
NO 4 N JUNK
1994 GMC K1500 XC 5.7L
2008 Chevy Impala LTZ
Old 10-29-2011, 03:17 PM
j cAT j cAT is offline
Re: '94 K1500 Transfer case ?
normally the transmission fluid gets into the transfercase causing it to blow out the transfercase vent.
when about 2qts of tranny fluid gets into the transfercase this can also cause no drive when cold starting .
if the transmission fluid is too high it is possible coolant got into it.
Old 10-29-2011, 06:22 PM
horse482's Avatar
AF -Advisor
J cat thanks for the reply but a nv4500 is a manual trans and has nothing to do with antifreeze/coolant.
NO 4 N JUNK
Old 10-29-2011, 08:13 PM
my son has the 1994 s10 5sp manual tranny. I should have caught that . so that would be another seal .
I have not done that seal . some seals are poorly made. did you get a GM OEM part last time ?
Old 11-04-2011, 10:14 PM
horse482's Avatar
AF -Advisor
The last seal I put in was a OE seal from my local GM dealer.
NO 4 N JUNK
Old 11-05-2011, 08:04 AM
when we got this 5sp 3years ago dexron III was in it. I replaced with synchromesh transmission fluid. this has the proper additives to protect the yellow bronze zinc metals in this.
shifting was very much improved. also the small leaks did reduce.
shifter gasket did need replacing.
Transfer Case Identification Project J10 General Discussion 2 03-26-2011 04:14 PM
1999 GMC Envoy Transfer case removal Bootsm Jimmy 0 12-05-2010 09:16 PM
92 K1500 Transfer case/4x4 issues. HELP!! hunter4ever12 C/K 5 10-18-2010 06:02 AM
89 K-5 with a tranny/transfer case problem curtisserrano 1969 - 1994 Full size 7 06-01-2010 08:14 AM
1993 K1500 Transfer Case Grinding gwjturner C/K 1 01-28-2008 08:41 AM
