Old 10-27-2011, 05:50 PM
gizm0327 gizm0327 is offline
1995 F150 4.9L straight 6 intermittent rough idle
I have replaced the plugs, wires, cap and rotors with no luck resolving the issue. It will only last about 5 mins, and then go away, either while I am driving or I can shut it off an come back 5 mins later and it will be fine. the ood time it will happen pop up while already driving. So does not matter if the engine is hot or cold. Have researched and can be one of many sensors and would rather not break the bank finding the problem. I have been able to rule out the idle air sensor. It is hard to try and fix since the problem is not always there.
Anybody else have this problem?
2004 F150 Intermittant rough idle Capt. Delta F Series 0 03-13-2009 10:43 PM
85 ford f150 4.9L 300-6 need vacuum diagram and carb info joshtech F Series 1 11-14-2006 09:02 PM
check engine light 92 f150 4.9L cyrax122 F Series 4 06-06-2006 03:18 PM
1995 G2 intermittant rough idle and stalling Vinpok Express | G Van 3 08-15-2005 09:30 AM
Cold Start Problem - '91 F150 4.9L ClydeWigg3 F Series 3 06-11-2004 08:57 AM
Tags
idle , intermittent , rough
