Old 05-31-2003, 10:58 PM
mtbrfrydr mtbrfrydr is offline
94 SE Sedan
Hello all I am new to the GP group, I just picked up a 94 SE sedan. I love it. I have one problem that I am working on with the way the engine runs.. It seems to have a slight miss in the engine and the car vibrates on acceleration... If any one else has experienced this please advise, your help would be greatly appreciated... I have already changed the plus and wires and am in the process of playing with moving the coil packs around to see if one is bad, but haven't had time for that yet.. Please help...
Thanks
Old 10-21-2003, 10:10 AM
wurmsh wurmsh is offline
It IS the coil packs going bad I had to replace both of mine when this happened
Old 10-21-2003, 08:56 PM
The Burning Rom The Burning Rom is offline
Send a message via AIM to The Burning Rom Send a message via MSN to The Burning Rom Send a message via Yahoo to The Burning Rom
Re: 94 SE Sedan
Um...Grand Prixs have 3 coil packs....so you must have only replaced 2 of the 3.
Checking the coil packs is a good idea though. find one that you know is good, and do what it sounds like you planned on doing.
www.wicgp.com <- Wisconsin Grand Prix Club
1999 Black Grand Prix GT Coupe
1990 Red ASC/Mclaren Grand Prix Turbo Coupe
1990 Metallic Blue & Silver Grand Prix LE Coupe
1979 Blue Dodge Ramcharger
Old 11-18-2003, 05:26 PM
92GPSE24VTDOHCV6 92GPSE24VTDOHCV6 is offline
I'm having a similar problem. I have a 92 SE, and it hesitates going up hills or sometimes when accelerating. I took it to a trans shop and they told me it wasn't the transmission, but the engine hesitating or missing occasionally. Shortly after that, the check engine light would come on, so I had a diagnostic done. EGR systems failure... so it could be your EGR valve. I haven't had this fixed yet, so I don't know anything for sure, but I was told that a messed up EGR valve or component can make the engine run rough. It makes the car shake up hills and when accellerating because that is when the transmission is under load. I'm no mechanic, but I hope that helps.
Old 12-14-2003, 05:18 PM
Elex Elex is offline
Re: 94 SE Sedan
What are the coil packs? I am having a similar problem like the person who owns the 92 SE. I own a 94 SE and just had the heads done cuz of blown head gaskets, then this hestitation come in to the problem. Any advice?
Old 12-14-2003, 06:17 PM
Ripn12s's Avatar
Ripn12s Ripn12s is offline
Send a message via AIM to Ripn12s
Elex,
Put some new plugs and wires on and if that doesnt work then try the coil packs. The coil packs are what the othe end of your spark plug wires are connected too.
Tim
Old 12-14-2003, 06:31 PM
kilroypr's Avatar
kilroypr kilroypr is offline
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
Re: 94 SE Sedan
My Z-34 had problems with the EGR but this never caused it to hesitate. Maybe poor milage but running normal. Since this is an old car makes sense to change the spark plugs. There is a quick test you can perform on the cables and it will locate a burned cable, bend the cable in small sections and will brake on the burned part.
IF this is ok then the coils. Coils Packs are the parts that will create a high voltage to cause a spark on the plugs to burn up the fuel-air mixture on the piston chambers and conversly make them move down to transfer motion to the flywheel and conversly transaxle/wheels.
Old 12-14-2003, 06:37 PM
Re: 94 SE Sedan
Originally Posted by Ripn12s
Elex,
Tim
Thanks, I'll try that, but someone said it has 3 coel packs, new spark plugs & wires has been installed. According to research on the net, it state to check the EGR valve & it's not a cheap part either. It's sure a rought ride when going up hill or increasing speed.
Elex ([email protected])
Old 12-14-2003, 06:49 PM
kilroypr's Avatar
Re: 94 SE Sedan
Elex:
When I replaced mine it costed me at least $150.00
it is easy to do, in my case the car did not gave me a rough ride. IT gave really bad mileage and resulted on a broken cable at the EGR pigtail
Old 12-14-2003, 06:56 PM
Re: Re: 94 SE Sedan
Originally Posted by kilroypr
Elex:
ON the net it cost from $247.00 - $269.00. I've replaced it once, about a year and a half ago, but after having blown head gaskets (due to water in oil) repaired, this start happening.
Old 12-14-2003, 07:26 PM
kilroypr's Avatar
Re: 94 SE Sedan
Well a lot expensier since the last time I bought them WOW.
Old 12-14-2003, 07:28 PM
kilroypr's Avatar
Re: 94 SE Sedan
Maybe those are list prices. Sometimes they can do better than that. But wow they are expensive.
