weather stripping problems or door bent
my 1996 chevy cheyenne v8 has a problem with the driver side door. its only a regular cab but anyway im not sure if the door is bent or if I just need to replace the weather stripping. If I shut the door its like it doesn't close all the way or latch all the way can push it the rest of the way but it does'nt stay there also if I look up from the inside of my truck I can see a little light but only on the back part of the door on top but the cab doesn't seem to drafty what do you guys think
Re: weather stripping problems or door bent
Door bent
Cab bent Hinges wiped out Striker mis-positioned Latch worn out Weatherstrip out-of-place/stretched
. . For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China. |
how do I eliminate these things
When MY truck had door problems, it was worn-out hinges. Common as dirt, especially on the driver's door. Grab the open door, lift up on the back edge. If the door lifts up with a "clunk" feeling, the hinges are toast. If the WHOLE CAB lifts up without any free-play in the door, the hinges are probably OK.
D-I-Y hinge repair kits are available at any "real" parts store; about $15 I think. In the Dorman "HELP" line. I had my hinges rebuilt by a body-shop; I think it was $45 but that was years ago. I knew a guy who made replacement hinge pins from small-block-Chevy valve stems, and just bought the bronze bushings separately. HIS hinge pins never wore out. If the hinges are worn out and not repaired quickly, the striker and latch get beat-up. Then you have to replace them as well. If the door or the cab is bent, you're looking at body shop time.
If you wait too long this can be expensive . pins / bushings are normally available. when the bushing bore is worn now your in trouble. |
ok ill look at it thanks
