Old 10-25-2011, 03:56 PM
luminasrus luminasrus is offline
95 3100 swap
I have a 95 lumina with a rotten frame,
what years/ models will engine and tranny swap into? thanks
Old 10-26-2011, 04:54 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: 95 3100 swap
Your '95 is OBD-1, OBD-II engines/powertrains started in '96.
So without some headaches modifying to meet standards of OBD-II requirements and ECM/equipment mismatch with the donor car, you are limited to 1994-1995 if you are trying to stick with the second generation body style....
I guess it could be put in a gen 1 Lumina body also, but probably not without a lotta unforeseen headaches...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
The Following User Says Thank You to jeffcoslacker For This Useful Post:
luminasrus (10-29-2011)
Old 10-26-2011, 04:56 PM
Re: 95 3100 swap
...perhaps a subframe transplant is the answer? Don't know the situation, but swapping it out is really much easier than transplanting the drivetrain....
But if the problem is BODY rot at the subframe mounting points, which is more likely, yeah, you got a mess.
...empty gun rack.
Old 10-29-2011, 02:09 PM
Re: 95 3100 swap
Thanks I was afraid of that. I wonder if engine and tranny would be an easy swap in any other models?
This one is rotted and one of the rear trailing arms has punched up into the frame. I had a welder look at it and he said their is just nothing to work with to make a repair. It only has 89000 miles on it.
3100 v6 leaking coolant from timing chain gasket? jamc204 Grand Prix 4 06-22-2010 10:18 AM
1996 Olds ciera 3100 swap. clampet Cutlass Series 1 09-23-2008 04:37 AM
Whole engine swap or head swap?? 90tegblackwidow Integra 10 10-15-2003 01:04 AM
COST$... H22 swap vs vtec head swap MXrider22 Engineering/ Technical 0 09-27-2003 11:54 PM
COST$... H22 swap vs vtec head swap MXrider22 Prelude 1 09-27-2003 11:52 PM
