Front End Noise
Good Morning,
My 2003 Silverado is has developed some front end noise. Mostly when making right hand turns. Seems to be coming from the front LH wheel. Kind of a grind, followed by a thumping. It goes away once turning is done and I'm driving straight again. Any ideas? Thanks, BJL |
Re: Front End Noise
If you think it's from the wheel area, and not the column, raise the ft and and check for play in the L/F hub bearing (top to bottom, side to side) sounds like maybe a failed bearing. Also rotate the wheel and feel for any roughness.
Re: Front End Noise
Thanks for the reply. As far as noise from the column, this is different and seems to be coming from the front LH wheel. Column noise- I have had the intermediate shaft issues and learned to live with it.
Re: Front End Noise
I am also noticing a slight squeal driving down the road. Wheel bearing possibly?
Re: Front End Noise
Good Morning,
Sorry to hear about this noise concern, but I see you’re getting some great feedback. If you would like to keep me posted, I am interested in hearing how things go! Best, Sarah GM Customer Service |
Re: Front End Noise
Could also be bearing noise. Have you raised and inspected yet?
Re: Front End Noise
these vehicles have many hub bearing issues as the seals used rust out in a few years of rust belt use. remove the wheel hub sensor and see it the grease is rusty/red color. the grease should be blue. if rusted the hub is N/G.. |
Re: Front End Noise
It was the wheel bearing I was hearing. I also have a noisey steer shaft. It moans and groans when turning. Something I am used to. Would like to get rid of it- but it's not a safety threat. So I will wait with that one.
Thanks for the help. BJL |
Re: Front End Noise
rather than make a big mess. I simply suck out all I can with the bottle hand pump that I use to fill the other oils. then add to the proper level with prestone GM power steering fluid with seal conditioner. after a week repeat this process. by then the pump will quiet down as the new fluid can create the proper pressures required to move the wheels. |
Re: Front End Noise
I was having similar problems with my car but had no idea to check the color of the grease under the hub sensor. My mechanic buddy told me that many cars have bearings that go bad because they are not packed properly with grease. Is this true? When I replaced the bearings on my car I spent more attention on the bearing itself and very little on the grease. Should I remove the bearings I replaced to repack them with grease?
Re: Front End Noise
Nate, you have posted in three different forums for the same problem and have not once stated what you are working on or what EXCATLY is wrong with it. How about picking one forum that applies to you and giving us ALL the info!
Re: Front End Noise
using bearing grease on these at every brake service is what I plan to do. I will use the same blue grease that these require. pump it into the speed sensor hole. some vehicles have bearings that require regular greasing. this is my 1996 impala SS... every 30,ooomi I clean and regrease these front wheel bearings. with the truck/suv type on this vehicle you cannot doi t as they are sealed .. what vehicle do you own that had this problem ? Last edited by j cAT; 12-13-2011 at 05:34 PM. |
Re: Front End Noise
I apologize for not giving all the details. I actually had my mechanic buddy look at my car and he said my wheel bearings were bad. I replaced them not long ago but he said they were probably not greased properly when installed the first time, which was my fault (woops!) So this weekend he showed me how to grease the wheel bearings : http://connect.timken.com/inadequate...gs-part-1-of-3
And thanks for your suggestion jCat. I will grease the bearings again the next time I have my brakes serviced. |
