Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 10-24-2011, 10:12 PM
scavengerspc scavengerspc is offline
06 Ram 1500 rear disk brakes
Can anyone tell me how to remove the pads from the rear calipers?
I have the caliper off and I dont want to force things. How do I properly remove the clip the pads hook into on each side? I assume I only need to remove one side to free the old pads.
Thanks in advance.
Dave
Old 10-25-2011, 01:31 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 06 Ram 1500 rear disk brakes
I'd use a screwdriver to pry the clips out with the pad then remove the clips like the picture recommends.
Here's something out of the manual,
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Rear disk brakes don't close after replacing Front Brakes blaisers99 Engineering/ Technical 1 02-01-2009 09:57 PM
Rear Disk Brake Conversion Wagon4wdRTI '71-'87 Civic | CRX 9 09-08-2003 01:35 AM
Rear disk brakes on 95 S-10? cobra1 S-10 1 08-21-2003 02:37 AM
rear disk brakes????? DelSol_Awesome '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 6 01-25-2003 01:21 PM
