Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 10-23-2011, 02:47 PM
virgamanda virgamanda is offline
Send a message via AIM to virgamanda
96 Prelude h23a1 to h23a3 swap with tdc sensor problem...Help!!
I have a 96 prelude that originally had a 2.3 h23a1 engine. It blew up so I replaced it with a used(23000 Miles) 2.3 h23a3, now I have no fire from the coil. The only difference is the old h23a1 motor has an external coil with a tdc sensor behind the timing cover and the new h23a3 has the coil inside the distributor and no tdc sensor, not even a place to put the one i took off the old one. I transferred the old coil and the old distributor to the new motor, is there a way to trick the pcm like a jumper in the connector or something. does anyone know how I can get this coil to fire.
Driving Olds Delta 88 with cam sensor problem me2maxon Eighty Eight 3 07-13-2007 06:59 PM
Problem with MAP sensor NEED HELP! Twyztidmind '88 - '91 Civic | CRX | Wagon | Shuttlee 3 09-26-2005 10:16 AM
engine light;h22 tdc sensor problem yoshi_h22a Let's get Technical! 6 09-22-2005 04:39 PM
Mass Airflow Sensor problems. HELP 94CamaroZ28 Camaro Discussions 10 05-27-2004 12:21 AM
