Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Members Projects
Members Projects Discussion of the AF 2G DSM Project Car
Old 10-23-2011, 11:26 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Silvr's new turbo setup
Hey guys, alot of you know I have done a lot of work to the car in the last few months. Heres what all what done:
Relocated battery to trunk
Relocated fuse box to behind the bumper
Moved ECU
Redid some wiring to clean up the bay
Powder coated valvecover
Built new top mount turbo manifold
Fab new downpipe
New intercooler and piping
Put the AC back in
There was a few other things that had to be done but thats the major parts of it. I tried doing another 8 injector setup but had issues with MS controlling the secondary injectors so went back to full stand alone. Its running pretty well at the moment. Only tuned up to 10psi, waiting on the intercooler pipes to get tig welded so I can add meth in and the IAC sensor. Then going to tune up to 27psi is the goal. Hoping for about 450whp. Car is going to be on a dynojet dyno so that should be easily obtained. Here are some pics!
I designed and welded the manifold out of schedule 40 mild steel.
Manifold welded up
Manifold cleaned and ready to wrap
Downpipe refabed and wrapped
New intercooler
Still got to keep the fog lights
Almost finished
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 10-23-2011, 07:54 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Re: Silvr's new turbo setup
Really nice man, Im really impressed. Manifold looks great. I was definately not feeling that ramhorn dealio manifold. I like your placement of the turbo. I noticed its a holset. Which holset is it? 3" full exhaust? 2.5" hardpipes? Where did you source the IC, ebay? Is that a stock intake manifold? What kind of rad fans are you running?
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 10-23-2011, 08:58 PM
Holset powered 420a
Thanks man I really didnt like it either since I had to dent the pipes to clear the hood. Yes its a holset hy35. I have been running that turbo for a few months now. Was pushing it to about 22psi before the change. Full 3" exhaust and 2.5 intercooler pipes. Stock intake manifold gasket matched and ported to 60mm for the throttle body. Intercooler is from ebay, has about 3psi of pressure drop across it which is more than I want but it cools like a beast. Even after several pulls its still cold. The rad fans are also from ebay, one actually had the motor lock up so only running 1 fan at the moment but havent had any cooling issues.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 10-24-2011, 09:12 AM
So the throttle body? I think Ive read about it before. Isnt it a jeep unit or something like that? As for fans, yea that sucks. I ran an off the shelf advance auto parts fan on mine with good results. So you said you got the ac on now?
Caleb
vanilla gorilla
Old 10-24-2011, 09:56 AM
Holset powered 420a
Yea the TB is 60mm off a 4.0L jeep. Bolts up with minor mods. Next summer Ill probably spend some cash and buy too good fans. Im sure with the AC on and a FMIC it will run hot in the summer. The AC is all in but has not be charged yet. Im not sure if the compressor is even good still. Probably will wait till next spring to charge it up
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 11-10-2011, 06:41 AM
ned032002's Avatar
ned032002 ned032002 is offline
IDK how I missed this thread! Lovin the pics of your progress and when are you getting it dyno'd?
BTW...that is one big ass turbo!
Old 11-10-2011, 11:25 AM
Holset powered 420a
Thanks ned, Im planning on having the intercooler pipes welded next week, then have to add meth in and the AIT sensor then its ready for some boost. Only on 11psi now
98 Eclipse GS Turbo
2001 BMW 325i - DD
Silvr's new setup... SilvrEclipse Off-Topic 35 02-18-2009 06:51 AM
3rd gen twin turbo setup on 2nd gen non turbo 13b? EnjukuRacing240sx RX-7 2 11-17-2008 05:15 PM
new turbo/intercooler setup gen1tsi Engine, Transmission and Drivetrain 4 01-16-2007 11:31 AM
BALLS OUT turbo setup...new tranny? Jszy Forced Induction 30 03-31-2004 03:50 PM
Used T25 turbo setup? kraznik Engine 0 12-05-2001 05:20 PM
