Old 10-22-2011, 08:15 PM
MarkWilliams64 MarkWilliams64 is offline
99 Astro Instrument Panel Light Bulbs
I have a 99 Astro, 225,000 miles.
I have a few gage lights that are out, not all of them so I know it is not something with the dimmer switch.
(Fuel and Voltage Gages)
Has anyone every replaced any of the bulbs?
I see where you can buy them cheap on Rock Auto.
Do I have to take the entire instrument cluster out to get to the bulbs?
Thanks for any help.
Mark
Old 10-23-2011, 10:29 AM
Blue Bowtie's Avatar
Registered Offender
Re: 99 Astro Instrument Panel Light Bulbs
The instrument cluster must be removed. It's not that difficult, just time consuming. The lamps are a mix of 194, 168, 161, and 74 mini and sub-mini wedge base lamps. A couple of the warning lamps are LEDs soldered to the I/P foil liner but those almost never fail. The low fuel and overtemperature lights are examples.
Old 10-23-2011, 04:43 PM
Thanks Blue Bowtie.
So looking at my service manual.
You remove the Instrument Panel first.
This is done by putting the Van in 1st and Tilting the wheel all the way down.
The service manual says the Panel just is held in by retaining clips.
It also sounds as if you to remove accdessory switches and disconnect the headlamp and accessories connectors.
Then the IP Cluster is held in by four screws.
Does that sound right?
What is the worst part of the job?
As far as the bulbs go are they available at parts stores like the Zone, O'Rielys or Advance.
Or do I have to go to the local dealer?
Thanks Blue for the help.
Old 10-29-2011, 09:09 PM
Wasn't to bad of a job.
The biggest difficulty was disconnecting the Head Light Switch Module, the Rear Wiper Washer Switch and the Rear A/C Blower Switch.
5 out of the 6 bulbs in the Dash were burn out, can't believe how bright it is now.
99 villager heat instrument panel light bulbs greg123 Villager 4 01-22-2013 10:01 PM
1999 Chevy Prizm - Instrument Panel light bulbs ( LED replacement) n1ckml007 Prism 0 02-07-2011 02:08 PM
Speedometer Display - Instrument Panel mooneyka Xsara | Xsara Picasso 0 01-06-2010 07:52 AM
instrument panel replacement bulbs??? Erin T Caravan | Voyager 2 02-03-2007 05:20 PM
