Go Back   Automotive Forums Car Chat > Lincoln > Continental
Old 10-22-2011, 01:55 PM
dflowers5 dflowers5 is offline
Front wheel wobbling between 25-30mph
I just got new tires, balanced them, and also got the ball joints replaced. My tires wobble at about 20-30mph. They don't wobble at speeds over 45 though. I don't know what's going on. Tires of spending money getting things fixed that aren't solving the problem. Do you think it could be tie-rods?
Old 07-27-2013, 11:27 AM
Probie's Avatar
Probie Probie is offline
Re: Front wheel wobbling between 25-30mph
To check for tie rod ends jack up the wheel and grab it at 9 and 3 o'clock and give it a good left and right jiggle. If it moves with your jerking... its a tie rod end.
To check ball joints grab the tire at 12 and 6 and do a similar shake down. If it moves with your jerks in that direction, its a ball joint or two.
Vibration at 30 mph may be something as simple as your wheels needing balanced or the tracking (alignment).
Hope this helps.
2007 Lincoln Town Car Signature Limited
4.6 L Modular SOHC 16V V8
239 hp (178 kW)
287 lb-ft (389 Nm) at 4100 rpm
What is better front wheel drive or rear wheel drive? auto600 Engineering/ Technical 1 05-03-2007 11:31 AM
Front end shakes between 25 and 45 mph. jspisz1 Caravan | Voyager 18 10-16-2005 07:25 AM
Front Wheel Wobble almund2 Windstar 2 01-21-2005 02:19 PM
HELP - Blazer wobbles between 20-25 mph jwolgast Blazer 13 01-18-2005 12:53 AM
racing from 25-30mph Kang114 Drag Racing 1 07-13-2004 02:54 PM
