Old 10-21-2011, 08:11 PM
micali micali is offline
96 grand am SE power pack
Does this look like it would cause issues with the car running correctly? The car just started acting up one day and I had to tow it home. I could get it to start but it would backfire and miss terrible. The minute I put it in drive it would stall. Now it doesn't want to start at all. Sounds awhful when its cranking.
I had the ICM tested and it shows it is fine. I had two codes that I pulled and one was p0300 and p0172. I had read that some people had issues with the vacume line that went to the pcm, i think that is correct.
Any suggestions would be appreciated.
Old 10-22-2011, 07:46 AM
Tech II Tech II is offline
Re: 96 grand am SE power pack
A vac line to the PCM? That's a good one.
That's the ignition tower, you have a picture of....
Have seen carbon tracking problems in that white tower, cause misfire problems......but also you could have a coil problem(there are two in the tower)....could even have an ICM problem.....I know you had it checked, but more often than not, ICM's don't fail when cool and tested....
If I had to guess, I wouldn't be leaning towards the ICM.....Have replaced a lot of towers, and have replaced some coils......
With that P0172, I would also pull the vac line to the F/P regulator to check for fuel in the vac line....
Old 10-22-2011, 09:17 AM
Glad you got a laugh from that one. It's the MAP sensor.
I'm going to check those first before I spend anything on the ICM or coils.
Thanks
2001 GM LS-C 2 questions/Ethanol & power on passenger side MrRealtor Grand Marquis 0 09-30-2010 02:11 PM
How To R&R 1998 Grand Caravan Power Steering Pump CarBob Caravan | Voyager 0 04-04-2010 10:59 AM
1989 Grand Marquis has no power a19thcfx Grand Marquis 2 03-29-2009 04:52 PM
General Hydrogen sells fuel cell power pack to Nissan Motor - Fuel Cell Today Automotive News Automotive News Desk 0 09-09-2006 10:10 AM
2005 pontiac grand power mikecox1 Grand Prix 1 01-10-2006 10:37 AM
