Go Back   Automotive Forums Car Chat > Nissan > Altima
Old 10-14-2011, 01:15 PM
iimar10ii iimar10ii is offline
Rough/low Idle on 2003 Altima.
Hey guys, My 2003 Altima 2.5 SL has a really rough Idle. It's way below 1000 RPM's when I'm Idling (in park or at a red light) and if I turn the AC on it gets worse and the engine rumbles and makes a rough noise until I accelerate and push the RPM's higher than 1000 RPM's. Putting the Car in neutral also pushes the idle speed back to where it should be for some reason. There's a check engine light on and I've tried the reset procedure where you disconnect the battery and all that and it did not work. What can I do to solve this problem? Do I replace the throttle body or the Idle Air control motor or both?
Old 06-25-2016, 05:57 AM
Eddiegari Eddiegari is offline
Re: Rough/low Idle on 2003 Altima.
I have the same problem with my 05 altima 2.5 can anyone help please
95 tsi really low idle and stalls.. Please help please Brenthb25 Eclipse Problem Diagnosis 3 07-20-2010 10:41 PM
'96 Camry 4-cyl 2.2L Idle Control Sensor Maulana Camry/Camry Hybrid/Vista 4 03-18-2010 10:29 AM
low idle/shuddering adamthecaveman Tercel 1 03-03-2010 07:38 AM
99 Taurus 3.0 duratec rough/low idle mudhen33 Taurus | Taurus Wagon 2 11-24-2007 02:08 PM
2003 Altima, Ticking noise, idleing rough chucksball Altima 6 04-02-2006 06:26 PM
Tags
altima , idle
