Old 10-13-2011, 05:21 AM
TheGeneralLee86 TheGeneralLee86 is offline
Send a message via AIM to TheGeneralLee86 Send a message via MSN to TheGeneralLee86 Send a message via Yahoo to TheGeneralLee86
Question Power loss after gas fill up and going through..
some water that was only deep enough to cause a rooster tail that came above the passenger fender when I was going through it kind of fast and I changed the spark plugs sunday and it did make a big difference but now there is still a slight power loss I am wondering what else I should try?
2002 Chevy Cavalier 2200sfi Coupe Base 81,800 miles
Old 10-13-2011, 06:20 AM
Tech II Tech II is offline
Re: Power loss after gas fill up and going through..
Can you be more descriptive of a "slight power loss"?
Old 10-14-2011, 06:53 AM
I would push down on the gas and it would accelerate a little slower then normal and I would have to shift down into 3rd from 4th where I normally would shift into if it was steep enough ( Mind you this is a 5spd Standard Transmission). But it would even do it on almost level ground sometimes, it has been doing this since my last gas fill up, Then I changed the Spark plugs on it and that helped considerably but it was still doing it a little bit though and then the last couple days it has slowly been getting better. I also put some shell gas into my car and that helped too now it seems to be gone so it may be it was bad gas or what else could of been?
I know I am still having starting problems though every once in a while?
2005 Grand Prix SE. poor fuel economy and power loss rogerwc Grand Prix 4 09-14-2011 08:33 PM
Problems after gas fill-up! jessdela Optima | Magentis | Lotze 4 09-28-2005 06:40 PM
S-10 Blazer lost power after gas fill-up. BlazerBurnt Blazer 3 08-22-2004 12:35 AM
S-10 Blazer lost power after gas fill-up. BlazerBurnt S-10 4 07-16-2004 07:27 PM
99 4.8 Backfiring after gas fill-up Bill-SILV C/K 5 06-16-2004 07:26 PM
