Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 10-12-2011, 07:24 PM
KevinCurtis121 KevinCurtis121 is offline
Exclamation Battery problems
I own a 2000 GMC Sierra and when the truck sits for 2 days, the battery dies. When i take the battery wire off, sparks come out & it's drawing power from somewhere. Has anyone had this problem before?
Old 10-29-2011, 02:23 PM
horse482's Avatar
horse482 horse482 is offline
AF -Advisor
Re: Battery problems
You need to start by finding out what is drawing the power. Use a test light or volt meter disconnect the neg battery cable and put the meter or the light between the two and start pulling fuses 1 at a time to see if the light goes out or dims, or volts change. The clock radio will always draw power to retain memory. If you have added a stereo system or other accessories I would start with them, someone may have hooked a power wire to a constant power and should have been hooked up to a switch power.
NO 4 N JUNK
1994 GMC K1500 XC 5.7L
2008 Chevy Impala LTZ
battery problems sirlimpalot '97+ 1 06-01-2010 02:34 PM
2005 Solara Battery Replacement Tips... Intuit Solara 3 04-15-2010 08:05 PM
1990 Accord - Tranny, speedo, battery problems winsett Accord/TSX/Accord Hybrid 2 12-03-2009 01:39 PM
2001 Olds Alero Battery Drain Issue Xenokira Alero 3 04-20-2009 10:04 PM
2001 Cavalier Battery Drain Problem - HELP amberdamber7 Cavalier Problem Diagnosis 25 03-25-2009 06:30 PM
