Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 10-12-2011, 12:53 PM
budscuz budscuz is offline
tcc not engaging
I've read a lot in here on tcc's, and the more I read the less I know. Is the tcc internal in the torque converter? Do they go bad? My '96 Bonny has 130k on it, and the tcc doesn't engage. I've thoroughly tested the circuitry controling the tcc solenoid in accordance to my aftermarket manual, and the solenoid is being turned on. In the driveway I manually activate the circuit and can distinctly hear the solenoid click. Can it be just the solenoid is simply wore out, not relaying the voltage for the tcc?
This looks like a tranny r&r to replace that solenoid. Is that correct? If so, should I turn it over to the tranny shop and have them give it a complete overhaul? I'ld rather not do the expense of all that if the tranny will last another 60k or more by just replacing that solenoid. Do I have to be well versed in automatic transmissions to replace it myself or is that a job for superman?
Old 10-12-2011, 06:00 PM
Tech II Tech II is offline
Re: tcc not engaging
Would help to know the year, engine and if any codes are set in the PCM....
Old 10-12-2011, 06:10 PM
it's a 96 with the 3800. No codes are coming up, I recon because the circuits are working properly.
Old 10-16-2011, 04:00 PM
After a Sunday drive to further analyze this problem I've discovered that OD/4th gear is not engaging. I'm starting a new thead. Thanks, guys
Old 10-16-2011, 04:12 PM
FishFind FishFind is offline
One Hot Shot
The tcc is the torque converter clutch. The solenoid is the tcc lock up solenoid and it is on the valve body in the pan. To replace the tcc you will have to drop the tranny. You can do the solenoid your self but may take you a little while. Dirty or worn out fluid can cause this as well as level of fluid. Worn out check balls short in wire for the tcc solenoid or a worn torque converter clutch can also cause this.
The Following User Says Thank You to FishFind For This Useful Post:
budscuz (10-16-2011)
TCC not engaging on a 3T40 Transmission ('91 Pontiac TS SE) Meridivs Trans Sport 4 09-07-2011 08:23 AM
a/c not working 02' pa clutch will not engage climate control prob also crnwb Park Avenue 1 07-17-2010 10:47 PM
transmission not engaging guys i need your help cyberfastpush Trans Sport 1 03-12-2010 04:58 PM
TCC not engaging, '88 budscuz M Bodies 2 02-20-2010 03:47 PM
AC Clutch Not Engaging and Cooling Fans Not Working (I think) 1999montana Montana/Montana SV6 3 03-06-2008 09:16 AM
