Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 10-11-2011, 10:38 PM
44runner 44runner is offline
The Famous Starter-NO Click
Trying to help a friend fix her car, Its a 95 Toyota 4runner Sr5 AUTO v6...She said she parked it, came back out tried to start it and nothing.
Starter was replaced with a new one-No click
Battery was replaced-No click
Jumped car- Same thing, No click
Replaced the wire from + to the fuse box -No click
When the key is in ACC power and everything works, Headlights shine bright with no dim.
When key is turned to try and start, the click dims out.
there is a "starter" relay in fuse box and also another relay along side of that near fire wall that clicks when one tries to start it. Tapped both of them while friend tried to start thinking they were stuck, Nothing.
Tapped starter thinking it was stuck, Nothing.
Any help? car is stranded
Old 10-11-2011, 10:52 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: The Famous Starter-NO Click
Check the ground (-) connection at the battery and at the other end (block). Make sure both ends are clean and tight.
Check both battery cables to make sure they are not badly corroded internally. If in doubt, replace them.
Have the starter checked. It may be a bad one.
Check the starter relay secondary side for continuity when power is applied to the primary connection.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 10-11-2011, 11:15 PM
where is the secondary side located?
Also just to get the car to the house whats the "best" way to jump the starter
Old 10-12-2011, 09:21 AM
Brian R.'s Avatar
Resident Chemist
There are four contacts on the relay. There are three contacts parallel to each other, and one perpendicular to the other three. The two contacts which are paired are on opposite sides of the relay. The pair that are parallel to each other are the primary, and the pair with one perpendicular to the other are the secondary.
The secondary is what I call the high current side and is switched by the primary or low current side.
The primary (parallel pair) must have continuity and the other pair (secondary, perpendicular pair) should not have continuity. Replace the relay if the above is not true.
Apply 12 v to the side with continuity (primary), the other pair (secondary) should then have continuity. In normal operation, continuity in the secondary side allows high current to flow to the starter solenoid. If you don't get continuity in the secondary side when 12 v is applied to the primary, you need to replace the relay.
Jumping the starter is very difficult to do without touching other portions of the truck and shorting out the connection, sparking, etc. I think it is a bad idea and I don't suggest you try it. You can also potentially create a circuit through your body by touching the cable and the chassis. It is easier and much safer to try cleaning the connections on the cables first.
Old 10-12-2011, 11:37 PM
Isnt the Relay good if it clicks though?
Also tried to wire in a relay like this:
Still did not work, but the starter relay ( i believe thats what it is) op the passenger fender near the top clicks.
Also sounds as if something is clicking near the shifter, (relay)
Any help?
Old 10-13-2011, 02:07 PM
Brian R.'s Avatar
Resident Chemist
The clicking only means there is continuity through the primary. The secondary circuit is just as important.
Test all the relays. The main starter relay is in the box on the driver's side by the front of the vehicle, if I'm not mistaken.
Old 10-13-2011, 04:54 PM
okay well i wired in the 30A relay to try and bypass all that and still no click.
Foot on the brake draws power, i leave the key to the "on" position and the radio reset ( this mean ignition is working)
Also will not start in "N" .
Old 10-13-2011, 07:10 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Try bypassing all that and run 12V from the battery straight to the smaller of the 2 terminals on the starter.
Don't hard wire it, just touch the wire to the terminal momentarily and see if the starter jumps.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 10-13-2011, 07:15 PM
So if it works this way, what can I eliminate?
Old 10-13-2011, 07:51 PM
So if this works what's my problem?
And if it Dosent I'm guessing starter? It's brand new though
Old 10-14-2011, 10:55 PM
the starter turns over when key is in the "on" position and taped on pos on battery.
think it can be the ignition?
or would i be able to just wire ACC to a switch and make it push button to start?
Old 10-15-2011, 12:01 AM
Brian R.'s Avatar
Resident Chemist
Relay or connections
Old 10-15-2011, 04:06 AM
Where does the wire coming from the solanoid lead to? Also where 12 v ign from ignition lead to?
Old 10-15-2011, 05:15 PM
so starter only "clicks" when i jump it to the pos.
Went to dealership and bought a new 'starter relay" kinda funny considering i thought the Auto had the NSS as the "starter relay".
Im not sure what it can be. Test light determined no power to starter signal wire leading to starter.
Old 10-16-2011, 12:36 PM
Brian R.'s Avatar
Resident Chemist
Did you test the old relay?
93 villager no click no crank no start klee2183 Villager 1 02-28-2009 08:04 AM
1987 300E full voltage, no click from starter! jackio172 E-Class 0 07-07-2006 09:56 AM
The famous Jared sexylexy COMPLETELY off-topic 27 04-12-2003 08:37 PM
