Old 10-11-2011, 07:00 PM
ahaus ahaus is offline
transfer case code b2725
I have a 2000 s-series blazer with under 35,000 miles owned by a little old lady. Has intermittent " Service 4 Wheel Drive " history. No current codes but does have a B2725 code in history. Every time it is in the shop all is well. I'm looking for any insight. Is this something she could generate by improper use/shiftting. Any and all help is appreciated. Thanks in advance.
Old 10-11-2011, 08:55 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: transfer case code b2725
This code is for the mode control switch for the t/case (select switch). Being as it is an intermittant condition, check the connector at the switch and the t/case module. The module is loctaed behind the panel, under the right side of the dash at the base of the "A" pillar. It is known for getting water in the connector. If it all looks ok, you may need the problem to get more consistant in order to diagnose.
The Following User Says Thank You to gmtech1 For This Useful Post:
ahaus (10-12-2011)
Transfer Case Identification Project J10 General Discussion 2 03-26-2011 04:14 PM
1999 GMC Envoy Transfer case removal Bootsm Jimmy 0 12-05-2010 09:16 PM
89 K-5 with a tranny/transfer case problem curtisserrano 1969 - 1994 Full size 7 06-01-2010 08:14 AM
Transfer Case DTC codes drolds72 TrailBlazer | Trailblazer EXT 3 08-18-2007 07:29 PM
Transfer case rear casing 1999bravada Bravada 9 11-30-2006 07:55 PM
