Old 10-11-2011, 12:56 PM
Firstymer Firstymer is offline
Exclamation Engine Temperature gauge
Hello, I have a problem with my engine temperature gauge not reading on the dash. I was thinking about just replacing the ECT sensor in attempt to resolve the issue. I’m afraid to spend an enormous amount of money on the sensor and it may not correct the issue. I would like to know how can I fix this problem?
00' GP SE v6 3.1L 130,700+KM
Old 10-11-2011, 02:27 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Engine Temperature gauge
The first place to start is with the sensor. If the gauge isn't working it may be an issue with the sensor or the wiring to the sensor. They are not that expensive nor are they hard to replace. It will just take a little time.
The Following User Says Thank You to GTP Dad For This Useful Post:
Firstymer (10-14-2011)
Old 10-14-2011, 01:09 PM
GTP Dad,
How do I go about replacing the ECT sensor? I’m assuming just unplugging the wire hardness that is attached to the sensor and unscrewing the sensor out; am I correct? Please advise.
Old 10-14-2011, 09:02 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
That's correct, but you will need to partially drain the coolant in order to bring the level lower than the ECT hole in the block. If you don't coolant will spill out while you remove the ect.
The new sensor should come with sealant on the threads but in case it doesn't you can use some teflon tape ensuring some of the threads make contact with the block.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 10-17-2011, 04:13 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Actually, don't use standard teflon tape on the threads, as the sensor grounds itself to the block and teflon tape will cause a bad ground. You should use electrically conductive thread sealant compound if the new sensor doesn't have it pre-applied on the threads.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
cold temperature gauge decprelude Integra 5 09-12-2011 11:28 AM
Video of erratic temperature gauge tell me what's happening ***video*** mtndew568 Aurora 1 10-07-2009 02:40 AM
check engine, temperature gauge fluctuations dperry F Series 5 08-30-2004 07:40 AM
