Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 10-10-2011, 10:16 PM
Olivia1234 Olivia1234 is offline
Ford Focus 'stalling' problems after driving off curb
Hi, I'm hoping someone here can offer a bit of insight before I take my car back to the garage please.
A couple months back I had the solenoid replaced on the car and then it was fine. But then someone (not me!) drove my car off a large curb at speed. After that the car was 'shuddering' on start up and seemed like it wanted to stall, but didn't. It did this more when the car was already warm, say if I'd driven to the store, turned the car off for 20 mins, and then started up again. I took it to the garage and they replaced the pvc hose (they said the valve was fine) which had a hole in it.
The car was ok at first but started shuddering again a few days later and is getting worse. There is a smell of perhaps fuel as well. It hasn't actually stalled but feels like it really wants to. Now it doesn't seem to matter if it's warm or not.
It's a Ford Focus wagon, 2002, 135k with recently replaced solenoid, air filter, fuel filter, spark plugs.
Can anyone offer suggestions of what it might be?
Thanks for your help!
Old 10-11-2011, 07:05 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Ford Focus 'stalling' problems after driving off curb
I would suggest you start by taking a look underneath the car to see if there are any obvious signs of damage. Possibly driving off the curb collapsed a portion of the exhaust, restricting the ability of the engine to breath. Also look for signs of impact to the catalytic converter(s). If they were impacted, the internals could have come loose and may be restricting flow as well.
-Rod
Old 10-15-2011, 05:49 PM
-Rod
Ok thanks. It seems to be much worse when it's raining. It was really bad when I wrote my post and it was raining a lot. It's been dry for the last couple of days and no problems at all! Could that be related, or give an indication of what it might be?
Old 10-17-2011, 09:17 PM
vgames33 vgames33 is offline
Get a spray bottle and wet down the ignition coil and plug wires. Look for sparks jumping (much easier to see at night). I've seen several Focuses with cracked coils that acted up in the rain. If you don't see anything wrong, try misting some other electronics/wires until the car starts acting up.
Old 12-03-2011, 10:43 PM
Turns out the valve seat went in the cylinder head. Smashed to pieces. Here's a photo.
They've told me a 2nd hand cylinder head won't be good enough and it needs a new one and they need inspect the piston. The other option is a new engine. Both very expensive options. How bad does it look to you?
I'm considering just donating it to charity.
2012 Ford Focus American Pride Focus | C Max 0 10-29-2010 11:55 AM
WTB: 2005 ford focus cd player good / bad Hanster24 Focus | C Max 0 07-25-2010 09:00 PM
2002 Ford Focus ZX3 problems Ceci Focus | C Max 4 11-18-2004 05:03 PM
Tags
curb , focus , pcv , stalling
