Old 10-10-2011, 08:34 PM
nimina nimina is offline
1999 Chevy Silverado, Where is shift solenoid "A"
Hello. My check engine light came on, so I took it to a Parts house and their scanner said shift Solenoid "A" is faulty. Anyway, where is this located ? I know It is inside the pan, but there are two of them and I want to replace the correct one. The truck is a 1/2 ton.Thanks!!
Old 10-10-2011, 08:49 PM
j cAT j cAT is offline
Re: 1999 Chevy Silverado, Where is shift solenoid "A"
post the failure code. what is the engine/drive train 2/4wd etc..
what are the vehicle issues ?
Old 10-11-2011, 01:22 AM
trannyman52 trannyman52 is offline
4L60-E?????,,,,,,2nd gear acting up????? the shift solenoids are interchangable,,,I would just swap them,,,see if code changes,,,..they are the 2 on the back of the valve body (the square ones)....my bet is on the reverse reaction shell failing!!!!!
The Following User Says Thank You to trannyman52 For This Useful Post:
nimina (10-17-2011)
Old 10-11-2011, 04:47 PM
It's a 4wd with the 5.3. I was told that it is shift solenoid "A". I can hear it making a clicking sound. I didn't notice it doing anything out of the ordinary, but didn't really hammer on it either. Thanks
1969 Cutlass
1971 Corvette
1970 BBC Monte Carlo
A few sleds too
Old 10-11-2011, 07:39 PM
this part is in the valve body. there are 2 of these side by side. they have a clip that holds them in place. they are spring loaded so remove the 2 wires to it and push on it slightly when pulling the locking clip.
normally these are replaced together/ both at this time.
make sure the fluid is not contaminated with particles. If you find alot of material in the filter/pan bottom you will need more repairs.
you will use dexron VI. do not use the defective DEXRON III which is now no longer licensed by GM. this was determined to cause these transmissions to fail.
back 10 years ago there was alot of these soleniods defective.manufacturing defects..since it has been working this long it may mean more problems ..these parts are cheap see what happens. you may luck out ..
sometimes this occurs when the pan drop knocks off the wires to them . then the transmission don't shift correctly after the fluid pan filter servicing.
The Following User Says Thank You to j cAT For This Useful Post:
nimina (10-17-2011)
Old 10-17-2011, 06:34 PM
Thanks again for the help. I replaced both solenoids and things are back to normal, I drove it to work today.
1969 Cutlass
1971 Corvette
A few sleds too
1999 chevy silverado rev/shift problem romi7612 Silverado 20 01-19-2016 10:17 AM
1999 Chevy Malibu starts up, dies, then starts fine aem1988 Malibu 3 06-10-2011 04:06 PM
1999 Chevy Prizm - Instrument Panel light bulbs ( LED replacement) n1ckml007 Prism 0 02-07-2011 02:08 PM
1999 Chevy Prizm - lock rod clip? n1ckml007 Prism 1 12-21-2010 10:41 AM
1999 Chevy Prizm - defogger switch light bulb ( LED replacement) n1ckml007 Prism 0 11-09-2010 10:26 PM
