Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 10-09-2011, 08:57 PM
p8ntman777 p8ntman777 is offline
2000 malibu no oil to rockers
I have a 2000 malibu ls 3.1L 101k i bought that would not start. The ecm had been changed and not flashed. befor i took it over to the dealer to be flashed i had my mechanic change the upper and lower intake and gasket because for some reason it had been cracked and welded around some of the ports and a threaded ear on the lower was broke off. after repair i had the ecm flashed and car started and ran fine except for there was a sound like a lifter tic. mechanic says its from sitting and needs to run for a while and it might pump back up. long story short i pulled off the front valve cover and put water lines back on and started it up and only one pushrod had a small oil flow. the noise does get alot quiter after several minutes of running, only run about a minute with valve cover off.
Any ideas what would cause this? Could it be from intake repair?
thanks in advance
Old 10-10-2011, 11:30 AM
maxwedge maxwedge is offline
A990 racer
Re: 2000 malibu no oil to rockers
I'd start by checking the oil pressure with an external gage.
Old 10-21-2011, 05:15 PM
thanks for the reply, sorry it took me so long. oil pres is 35-40 psi at the plug next to the filter.
Old 10-21-2011, 06:21 PM
A990 racer
Let it run a little longer if no pressure to the rockers there is an internal problem, 3.1's that ran for an extended period of time with a coolant intermix can spin a cam bearing causing this issue.
2000 chevy malibu start car but shuts right off sdrouin06 Malibu 1 08-14-2011 03:02 PM
96 Geo Metro Lsi with tapping rockers AsylumEscapee Metro 0 07-13-2009 03:07 PM
Horrible oil leak 2000 Malibu 3.1L V6 tigerstrike363 Malibu 2 03-12-2006 10:32 AM
2000 Malibu Reprogram OddModder General Discussion 2 01-23-2004 11:25 PM
2000 Malibu near-continual chime question ukemigrant Malibu 3 01-10-2003 07:14 AM
