Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 10-09-2011, 12:22 PM
Stale Trooper's Avatar
Stale Trooper Stale Trooper is offline
Is anyone using the 'replacement' LED light bulbs?
Is anyone using the 'replacement' LED light bulbs such as these?
http://cgi.ebay.com/ebaymotors/3157-...item2a11f8c29e
Did you have to buy anything beyond the bulbs for them to work?
I bought some years ago at Wally-World, but they required an additional resistor or something that was 4X the price of the bulbs. I'm hoping maybe someone is making them with built in adaptors now?
Stale Trooper
'05 CVPI
(My '99 got wiped out with 238,513 miles on the clock, stupid woman driver)
It's White, with a black grille, a spotlight, and the butt is black. Need a picture? Thought not
Old 10-09-2011, 05:32 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: Is anyone using the 'replacement' LED light bulbs?
I never tried any LED bulbs. HIDs usually require a lot of extra work, not sure about the LEDs.
I rewired my headlights to bypass the Lighting Control Module (LCM). When I turn on my headlights, it engages a relay which is wired to the battery (through a 20-amp fuse), and then to the headlights. High beams are wired in the same way through a seperate fuse and relay. The effect is SIGNIFICANTLY improved light output. You are guaranteed to notice it over any sort of headlights you can buy. All of this can be done for under $50.
Here are some images of the harness that a friend made me. It isn't hard to make. This is a drop-in one he made for me so I did not have to cut any wires, or solder anything. If you go the home-made route, it won't take more than a few hours with a soldering iron and some wire cutters.
http://richgannon.net/gallery/thumbnails.php?album=17
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
The Following User Says Thank You to Blue)(Fusion For This Useful Post:
Stale Trooper (10-12-2011)
Old 10-12-2011, 09:23 AM
Hey Blue!
Thanks for the 'Relay tip'!, I'd been looking for that for some time as well; could you have your friend add a parts list (IE: wire sizes, and connector sources, etc.) and show how the stock wiring was used to control everything? Please. Give the response on here please.
My origional question was in reference to the LED replacement lightbulb units such as sold on Ebay for other exterior lighting (park/turn, & brake lights).
Thanks!
Stale Trooper
'05 CVPI
Old 10-29-2011, 08:23 PM
I can't site the other forums on these forums per policy, but if you Google "crownvic headlight relay harness" you will find plenty of information. You may have to join to see the "howto" data.
Stale Trooper (10-30-2011)
Old 06-01-2012, 08:31 AM
Originally Posted by LinwoodKellon View Post
Many of the light fixtures in my house use the small Candelabra base bulbs. Although they use 20-25w per incandescent bulb, that adds up to 50w and 100w for several of the rooms (and chandeliers). ALL of these bulbs have small, individual Flexible LED Strip Lights shades covering the bulbs.
I've replaced most of the standard base incandescent bulbs with compact florescent bulbs to save on energy costs, and I want to do the same with these bulbs. I know there are compact florescent bulbs are available in this size, but I'm curious about venturing into led strip territory even if it costs extra in the short term. I'm most interested in long-term savings.
Normally, high density led are used for directional lighting, but with the lamp shades, is it possible to get a similar amount of light? If yes, where can I find these bulbs?
Linwood, Not trying to be rude here, but what do your house lights & fixtures have to do with automotive applications?
In answer to your question though; do a 'Google' or 'Bing' search for LED home light bulbs, there are many sites now that offer them. Just look for 'lumens', 'Kelvin' ratings, and candlepower to select the best "bulb" for your needs. The higer each of the above listed ratings are, the brighter the bulb. To the best of my knowledge (and I have researched LED lights for much the same reasons as you), the current offerings aren't all that effective, but progress is often being made , and there could be something I have not seen yet.
Again, I don't mean to be rude, and you probably made an honest mistake in this posting, but this is an automotive forum.
Stale Trooper
'05 CVPI
Old 06-01-2012, 10:07 AM
danielsatur danielsatur is offline
Try www.tmart.com, for LED Auto and home.
Regular light bulbs waste too much power and generate heat when your trying to keep a house cool.
Old 06-07-2012, 05:01 AM
Berldn's Avatar
Berldn Berldn is offline
Send a message via AIM to Berldn
Originally Posted by danielsatur View Post
Try _____, for LED Auto and home.
100 percent agree. LED is better to use than bulbs.
http://www.niceledlights.com
Old 03-14-2013, 12:58 PM
TheBigfut TheBigfut is offline
Having issues with my '93 Crown Vic's headlights. Went to follow the link earlier in this post so I could get brighter headlights by bypassing the LCM and it's now a dead link. Can anyone help me out or will it be different for my '93 from the '99 ?
Old 03-14-2013, 11:32 PM
Hey Big! I think I've found the link you were looking for, or at least one that covers the question of lights & lighting relay use quite well.
http://www.danielsternlighting.com/t...ys/relays.html I found this by Googling "relay to run headlights" for additional Information resources. Just be sure to use good quality parts.
I would also suggest doing this only on the high beams side until you (a) get it working, and (b) check you local regulations to make sure you will be legal.
(usual follow up dissertation on not being liable, follow all safety procedures, don't drink & drive, use a condom, come in out of the rain, and don't run with scissors)
Good Luck!
Stale Trooper
'05 CVPI
1999 Chevy Prizm - Instrument Panel light bulbs ( LED replacement) n1ckml007 Prism 0 02-07-2011 01:08 PM
1999 Chevy Prizm - defogger switch light bulb ( LED replacement) n1ckml007 Prism 0 11-09-2010 09:26 PM
LED Light Bulbs??? bigdawg703 Silverado 1 09-12-2006 08:33 AM
Tags
led , lights , tail
