Old 10-04-2011, 05:14 PM
gpn50 gpn50 is offline
heater speeds
2000 f-150...heater/ac only works on high.The haynes manual leads me to believe that the thermal limiter is defective. I cannot find it as they describe in their book. Any help would be appreciated!
Other than a defective blower control switch what else would cause this?
Any other ideas!
Thanks
Old 10-04-2011, 10:13 PM
jyount jyount is offline
Re: heater speeds
It is the resistor network, hands down....
Lay on your back and look up in the passenger's floorboard. The network is next to the blower motor itself. If it isn't working on the others, when you pull it out, you will probably find a burnt spot on it. The side you can see in the floorboard is only a connector. It is brownish junkboard type color and somewhere around 3 or 4 inches long and an inch or 2 wide.
10 hours away from John Deere master certified
also master certified ASE tech. Exp. in both.
Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training
Gave up wrenching for "Greener Pastures"
Current job: RN
2010 Silverado Z71 5.3L 65xxx
Wife's
2007 Suburban 1500 LTZ 5.3L 102xxx
Old 10-05-2011, 04:18 PM
Re: heater speeds
Jyount...thank you!
I found the board exactly where you said it would be. It had a burn mark as you said it would and was so corroded that some of it crumbled right in my hand.
You called that one...thanks again!
Old 10-05-2011, 05:08 PM
Re: heater speeds
Thanks for the update, and you are welcome! That is the only reason I hang around these sites, I have a desire to help others.
Current job: RN
Wife's
infamous speed selector issue surrender Impala | Impala SS 4 01-11-2011 02:20 PM
AC / Heater Fan speed Switch ibkafn8ed Cherokee 0 07-05-2009 02:26 PM
prob with heater speeds scrapdaddy Silverado 5 09-01-2008 07:51 AM
