Go Back   Automotive Forums Car Chat > Chrysler > PT Cruiser | PT Cruiser Convertible
Old 10-03-2011, 05:14 PM
FordBoss88 FordBoss88 is offline
PO340 Error Code
(2006 PT Cruiser Touring)
I am having trouble ridding my PT of the 340 code.
My OBDI reader states that it is the Cam Sensor.
I replaced the Cam Sensor and then it threw a PO344 code. The 344 Code stated that it was the crankshaft sensor. I then replaced the crankshaft sensor.
Things seemed fine for a few days and it then re-threw the PO340 code. Since I purchased an aftermarket CMP, I decided to replace back the Mopar CMP. Again things were fine for a few days.
I then researched and some stated that the wiring loom was getting too hot. The black corrugated plastic sleeve that contains the wires had been cracked and nearly disintegrated, so I replace that and moved the wiring harness away from the coolant hoses. Yet I still have the code.
What is the solution. I have ordered a new Mopar CMP from the dealership and am awaiting that part.
Also the green seal inside of the CMP is failing and leaking a small amount of oil, could this be the culprit?
Thank You.
Old 10-06-2011, 11:14 PM
hundahunta hundahunta is offline
Re: PO340 Error Code
try and wiggle the harness near the throttle body. There is a tie strap that holds the harness to the tb the wires tend to go bad
01 Town & Country error code explanation jehanny Caravan | Voyager 3 10-14-2009 12:34 AM
2002 QX4:Error Code P1320 Michael.Jones Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 0 07-20-2009 11:09 AM
error code 300 no other codes brokeneckdave Blazer 6 02-07-2005 05:20 PM
Stalling, Bad Error Codes, Strange Error Lights mrwjr2003 Regal 0 05-21-2004 09:34 AM
Engine error code Pancor Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 3 03-12-2001 10:31 PM
