Old 10-03-2011, 01:41 PM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
purge valve question
I have been chasing a p0455 check engine code a large evap leak. I just got a vacuum pump gauge and I added vacuum and it isnt holding. That mean the valve is no good right? Shouldnt it stay at like 9?
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
2002 Dodge Grand Caravan sport 3.3, auto
located in beautiful New England.
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
Old 10-03-2011, 06:40 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: purge valve question
Never dealt with it but I'm wondering if you can disconnect the vacuum lines at the valve and plug them to take the valve out of the system then try your leak test. Here's a video that shows how a shop t-shoots EVAP leaks on an 02 Caravan.
http://www.youtube.com/watch?v=CSn0ljUS6kI
Don't recall if it's pressure or vacuum but I've read applying too much of one or the other can damage EVAP components.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 10-03-2011, 06:59 PM
chevyn0va1's Avatar
I took it physically out of the van and put it on the bench and connected my vacuum gauge. squeezed till 15 lbs and it just leaked out. I checked my connections so I'm sure it is the purge valve leaking. I tried both ended of the valve. I didnt check the solnod though What I have read the intake side of the valve should hold like 9 lbs and then when you apply voltage the vacuum is released.
Old 10-22-2011, 04:12 PM
CRF230dad's Avatar
CRF230dad CRF230dad is offline
I discovered 3 - error codes P0442, P0443 & P0455 after taking my 03' Suburban to get smoged. Went to my mechanic who did a smoke test found leaks on both (cracked vent/rollover valves) from the top of the fuel tank. Fuel tank replaced, $1,100 dollars later code P0455 came back after a week or two . Back to mechanic discovered bad contact where the wires connect to the molex connector to the canister purge control solenoid while moving wires around because it would work then not work. He ordered the connector, I replaced it myself. Took it back so he could clear the code. Code back (P0455) after a week or two. I replaced the gas cap with an OEM. Took it to my friend who read and cleared the code. Code was back after a couple weeks. Where do I look next? Please help I'm going crazy. I really need a DIY fix cause I'm running out of cash....
purge valve question jrk-offf Seville 0 10-07-2008 09:58 PM
99 altima purge valve stuck open slinslv Altima 0 03-12-2005 12:01 PM
know about the canister solenoid purge valve? lynne1623 Camaro Discussions 0 10-29-2003 07:47 PM
FYI - Charcoal Canister and Purge Valve MauiBlueGRide Maintenance 0 12-28-2001 05:08 PM
