Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 10-01-2011, 01:13 PM
hotpipes hotpipes is offline
2002 malibu radio disable lock out
I would like to work on my 2002 malibu. I need help to disable the radio lock out? I know there is a number of buttons you push on the radio but dose any one know the sequence to disable the lock out?
The manual dose not give me any ideas for doing this.
I'm not sure that the instructions JAW9 gives on this form will work for my 2002 malibu.
hotpipes
Old 10-02-2011, 12:19 PM
Tech II Tech II is offline
Re: 2002 malibu radio disable lock out
Not sure about this, but I think from 2000 and up, you need a scan tool.....you can't do it manually anymore.....
Old 10-02-2011, 03:41 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
What kind of work are you doing? If you just want to remove then reinstall the same radio in the the same vehicle, it will not lock up because the VIN# is stored in the appropriate modules.
techII is right, a scanner must be used on this one to unlock it.
Old 10-02-2011, 04:12 PM
Thanks to both gmtech1 and techII for your response!! I will look to buy a scan tool if there not to expensive. Would you guys have any suggestions for getting a reasonably good one and do the parts stores have them?
hotpipes
Old 10-03-2011, 12:11 AM
gmtech1's Avatar
The only scanner I'm aware of that will do this is GM's TECH2. It'll run you about 2500.00. Like I said before, if you just unplug the radio and plug it back in, it'll be ok.
Old 12-06-2011, 10:30 PM
driveraven driveraven is offline
Just be careful with this, some cars with completely lock you out because of security issues.
'97 grand marquis - locked out drawde02740 Grand Marquis 1 06-30-2009 03:40 PM
2002 Malibu Power Locks Relay Location slee01 Malibu 2 01-23-2007 11:50 AM
99 malibu radio locked? starygurl82 Malibu 4 10-06-2006 06:33 PM
replacing OEM radio\cd with upgrade OED radio/cd/cass in a 2002 Malibu monkey123 Malibu 0 08-16-2005 10:56 AM
Radio locked out in 2000 Malibu caterpillar1957 Malibu 4 06-16-2004 01:29 AM
