Old 09-29-2011, 08:14 PM
mythirdeye mythirdeye is offline
Brakes on a 2000 Dodge Grand Caravan
Hi guys, thanks in advance for any advice you can give.
When braking in the van there's an intermittent problem with the brakes. We'll be braking fine when suddenly the pedal will press right down and the brakes lose a ton of their effectiveness. Again, it only happens once in a while and after it happens, they work fine again for quite a while. It's only happened at slow speeds (so far). The wife says pumping brings them back.
The fluid level seems fine, I did top it up and I'm keeping an eye on it.
Some background: We bought the van earlier this year and replaced the front caliper. There was still a problem during the safety. The mechanic loosened a clamp on one of the lines saying it makes a pinch point over time, and it worked fine after that. The brakes have been great for months.
soooo... leak? air in the line? ABS sensor? What are your thoughts?
Old 09-30-2011, 01:44 AM
hundahunta hundahunta is offline
Re: Brakes on a 2000 Dodge Grand Caravan
sounds like an internal leak in the master
The Following User Says Thank You to hundahunta For This Useful Post:
mythirdeye (09-30-2011)
Old 09-30-2011, 06:02 AM
mishalah's Avatar
mishalah mishalah is offline
You either have air in the system or a leaking cylinder (wheel or master). GET IT FIXED RIGHT AWAY! You have an accident just waiting to happen.
The Following User Says Thank You to mishalah For This Useful Post:
Old 09-30-2011, 06:11 AM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
I used to have a car that was loosing fluid but the wheels were dry, come to find out fluid was leaking behind the brake booster running down the firewall. Check that area for wetness. But do something right away like other posts that is a problem waiting to happen and not to be taken lightly.
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
2002 Dodge Grand Caravan sport 3.3, auto
located in beautiful New England.
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
The Following User Says Thank You to chevyn0va1 For This Useful Post:
Old 09-30-2011, 07:24 AM
b1lk1 b1lk1 is offline
Van should not even be driven until fixed. Master cylinder failure is common on these vans as are sticky calipers. Your problem is most likely a failing master cylinder. For the little it costs to replace, it is cheap insurance that your wife doesn't lose braking while entering an intersection.
Not to sound overly dramatic, but this can easily lead to major injury or even death.
PS: Nearly impossible for the ABS to do this unless the ABS module itself is leaking. If there were a sensor failure the ABS light would be on and the ABS would be inoperable leaving the regular braking system fully operable.
The Following User Says Thank You to b1lk1 For This Useful Post:
Old 09-30-2011, 05:55 PM
Thank you all for your help. Looks like I'm changing the master cylinder tomorrow.
2000 dodge grand caravan e brake won't release nymike Caravan | Voyager 3 06-06-2009 12:59 AM
2000 dodge grand caravan stalls..3.8 ltr engine t_pizzo Caravan | Voyager 5 01-02-2006 05:51 PM
Tags
brakes
