Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 09-29-2011, 06:34 AM
kvn4 kvn4 is offline
95 jimmy odd performance
after driving about 30 miles and getting off xway truck seemed to want to stall but didnt. anyway started running strange ,wouldnt shift properly, shaky,hard to keep running so eased my way home doing 60mph .read codes and got po325 knock sensor, po137 o2 low volts, po107 low map, and po122 tps low input. found loose neg cable and removed to clean and retighten. all codes gone except tps code. bought a new one and on way home all went back to normal so didnt install new tps. started truck this am and runs smooth. well shall be driving same route today but with new tps and tools in tow in case problem happens again. any other possibilities as to what caused this. will let you know out come this afternoon as to if get same condition.
Old 09-29-2011, 08:00 AM
squekyj squekyj is offline
Re: 95 jimmy odd performance
those vehicles are really bad for carbon to get stuck in the egr valve and keep it open and cause a large vacume leak.. which would explain alot ofthose codes and would not want to idle..and have horid performance and brakes would be a lot harder to push down.. not really a causein ur case but worth a shot to look at anyway in the future..
Old 09-29-2011, 01:03 PM
i was thinking the egr also. well did same trip and alls normal, think like you suggested egr valve had alittle carbon and it must have passed. thanks k
Selling or Parting 93 jimmy 4x4 4.3 Votec(w) ibceng Classifieds 1 10-08-2009 03:34 PM
Blowing ECMb fuse 1990 gmc jimmy 350 bmxer20n Problem Diagnosis 1 07-10-2009 05:47 PM
1996 Jimmy replacement of gaslines 600cuin Jimmy 0 06-22-2009 01:26 PM
87 jimmy wont start Chevygirl04 Problem Diagnosis 1 04-09-2009 06:44 PM
92 Jimmy Dies When Idling rockavenger Problem Diagnosis 3 03-10-2009 09:52 AM
