Old 09-28-2011, 09:45 PM
tacosoldier tacosoldier is offline
Do any one of you Intrigue owners have this annoying problem?
Ok, I've had quite a time with the turn signal bulbs and its getting on my nerves. About three years ago I purchased a headlight assembly complete with all the sockets and bulbs, which I went through a body shop to get at a reasonable price. Fast forward to last year, the turn signal in that asembly plus in the other stopped working. The rear signals work fine. First, I pulled out the newer asembly and to my horror, wasnt authentic GM parts (you get what you pay for). The sockets and wire harnesses are way different and the wiring is thicker than the GM version.
Looking at both signal sockets, they both seemed to have experienced alot of heat as they were both burnt. I then went to the local GM dealership here. Showed the parts dept the aftermarket socket with the GM socket. He ordered a replacement socket but tried to locate a parts number for the aftermarket assembly to try to order me another, there was no parts id. He told me that recently GM no longer sends headlight assemblies complete, you have to individually purchase the sockets. It would've ran me over $200. I said screw that just order me the one socket.
Once it came in, put it in worked fine until now. Replaced bulb, no effect. Checked socket, and looks burnt. Wanted to hulk out and smash stuff. What is with the turn signals on this car? Is GM making crap-tacilar parts? Any insight will help.
Old 09-28-2011, 10:47 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Do any one of you Intrigue owners have this annoying problem?
I can't explain why it happens, other than it's caused by high resistance. Next time you replace the socket and bulb, apply die-electric grease to the socket terminals and bulb contacts. Be pretty liberal with it, but not just a big blob either. This should help and/or eliminate your problem.
Old 09-29-2011, 08:10 PM
Yeah, I applied diaelectric grease to the replacement bulb three weeks ago and it went out. When I pulled the bulb from the socket, the area where the grease was at was white and dry, looking at the socket, it looked like some parts of it melted during that time. I do have half of mind cussing out someone at GM corps but I know it wont get me any where.
Old 10-07-2011, 03:48 PM
Insomaniac Insomaniac is offline
I can tell you why this happens. It is the flasher in the Intrigue, except it isn't set up like a normal flasher in most cars. It is integrated with the hazard button
The part costs about $70 shipped and is described as the hazard switch. I had burned through 3 bulb sockets before replacing this and have never had a problem since.
Old 10-07-2011, 06:49 PM
gmtech1's Avatar
Interesting...had'nt heard of that causing this concern, good to know.
Old 10-10-2011, 04:40 PM
Originally Posted by rhaigh08 View Post
Typicly the hazard switch will also cause complete tail light failure. And dash failure for the turn signals. It's worth a try but I went through several sockets on both my intrigues. It is a gm thing.
Never had issues with it other than burning out the bulb sockets. But that is no longer a problem either since I got the new hazard/flasher switch
Old 10-13-2011, 09:44 PM
panzer dragoon panzer dragoon is offline
dialectric grease is expensive, high voltage, and is used for distributers etc.
You should be using bulb grease or conductive grease.
Using dielectric grease on a bulb with either work extremely well if there is good metal to
Metal contact (grease will insulate voltage in) or will provide a mountain of resistance if the grease is between the metal contact.
Old 11-04-2011, 08:30 PM
meengrinch meengrinch is offline
i have had problems with my 2000 olds intrigue directionals not working occasionally. when they stop if i grasp the hazard button and shake it the directionals will work fine.....i should replace that switch but haven`t done it yet.....
Old 11-15-2011, 07:47 PM
Thank you, I'll look into this. Never thought to look there, though it should have dawned on me considering a year ago I replaced the hazard switch on my wife's Pontiac Grand AM. It was causing turn signal issues, it wouldn't blink most of the time. And when it wouldn't blink, it made an annoying "buzz" noise until switched off. I'll definately look into this and thank you.
Old 06-07-2012, 04:14 PM
i_hate_cars38's Avatar
i_hate_cars38 i_hate_cars38 is offline
Lost In The Darkness
i had blinker problems and light problems etc went to junk yard got all new housings now works fine i had a burnt socket but works fine blinkers goes out but i smack the crap out of hazard switch and blinkers stay working for long time the hazard control has allot of the blinker crap in it and maybe more its a 100 dollar part so who knows try junkyards and lens cleaner they will look like new
All the great things are simple, and many can be expressed in a single word: freedom, justice, honor, duty, mercy, hope.
Winston Churchill
The most difficult phase of life is not when no one understands you,
it is when you don't understand yourself.
«It's good to know that if I behave strangely enough, society will take full responsibility for me.»
Old 08-05-2012, 02:54 AM
djc937 djc937 is offline
I had this issue with my 2000 oldsmobile intrigue One replace both headlight Assembly's with the aftermarket one that meets OEM specs cause there sealed better and the wiring in the aftermarket ones is thicker and much better the run about 80 dollars per assembly second replace the hazard flasher relay its built right into the flasher button to fix this pop out the center vent above the radiator with flat head screwdriver be careful not to break it the right in side the hole to the left youll see ith a plug and play type of thing just pinch the bracket and it pops out reverse to install new one this fixed my issue never had problem since
Have any of you heard or tried this? vr4JoE22 3000GT/Stealth 10 04-14-2005 07:53 PM
Any of you Intique owners interested in a new Olds forum? kjh_2005 Intrigue 0 04-07-2004 10:58 PM
dose any one live in utah have a radiator boosting20psi Off-Topic 0 01-14-2004 11:38 PM
Any of you Odyssey owners have these! drifter350 Odyssey 1 11-29-2003 05:50 PM
what do the rest of you G20 owners have on your desktops??? cliffud General 64 04-12-2002 08:56 AM
