Old 09-27-2011, 10:42 PM
Neilfj Neilfj is offline
Question 1999 escort extreme loss of power
I'm going nuts trying to find th problem with my car
1999 escort se 2.0 SOHC 5 sp M/T
It has no power at all and sometimes will barly even run in first
Ive tried the following:
Replaced plugs, wires and coil pack
Replaced fuel filter
Checked air filter
checked EGR
Tried runnung without EGR Tube to checked for plugged cat conv, but still had loss of power
Computer Shows no codes or pending codes
Checked for vacuume leaks, could not find any
Fuel pressure was 35-40 psi
Compression was 150psi
Any thoughts from anyone, I'm stumped on this one
Thanks for any sugestions
Neil
Old 09-28-2011, 08:44 AM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
Re: 1999 escort extreme loss of power
Have you tried a vacuum gage? Low vacuum would indicate a clogged exhaust system.
Are you testing the fuel pressure before or after the pressure regulator? I was thinking that it could be bad.
Nevada Tumbleweed
Old 09-28-2011, 11:23 AM
Intuit Intuit is offline
Timing belt slip.
Properly read vacuum testing will identify this and most other mechanical issues. But as a matter of investigation you should check the timing marks directly.
Old 11-02-2011, 03:39 PM
frafreg frafreg is offline
Are you sure you don't have a blocked exhaust? The catalytic converter could be blocked or the muffler.
1999 escort clicking sound Jaclyyn Escort 1 06-26-2011 09:51 AM
99 Camry Brake Power Booster going bad? ccyphers Camry/Camry Hybrid/Vista 4 03-18-2011 07:45 AM
power steering problem in the rain eu0688 Impala | Impala SS 2 12-14-2009 12:23 AM
Power Loss in an '89 4Runner toyotatech89 4Runner/GX470 6 08-07-2009 02:23 PM
