Old 09-27-2011, 09:37 PM
crustyalero crustyalero is offline
sash clip/window channel guide
In looking for the sash clips/window channel guide/window clip on this forum... I found some part numbers from GM.One is the 22697622 or 22697623, depending on the driver's side or passenger's side door. This is listed as "CLIP," for $27.35. The other part number is 12337848, the ten pack, listed as "GUIDE, REG," for $1.82.
What is the difference between these two? I don't understand the 10 pack because you need to distinguish between which door they are for. Are both sides included? There should be a total of eight in a four door Alero, so why ten? Also, there is a big price difference. Can you really get 10 of the $27.35 parts for $1.82?
Is the $27.35 part just the plastic, or is it the little metal "L" too?
Thanks for the help.
Old 09-28-2011, 09:20 AM
Tech II Tech II is offline
Re: sash clip/window channel guide
Not sure....if you are talking about the plastic clip that is glued to the window, and attaches to the the regulator, I believe there is only one number, because it fits all four windows(if a four door), and is probably sold as a 10 pack......and they have to be installed the correct way, not backwards...if we are talking guides, those would be different for passenger and driver sides....
Old 09-28-2011, 10:08 AM
No, not the part that is glued to the window. There is a metal bracket that connects to the part that glues to the window, and on that metal bracket is a white plastic clip that guides the window up and down the rail. That is the piece that I'm talking about.
Those part numbers are GM part numbers.
Old 09-28-2011, 06:17 PM
Are you talking about the part that is attached to the regulator cable/plastic ribbon, and slides up/down with the cable/ribbon?
Old 09-28-2011, 08:56 PM
I've been a little confusing in the way I asked the question...
I would like to know the difference in the GM Oldsmobile part numbers 22697622/3 and 12337848.
If anyone has ordered one of these, please let me know what you got.
Old 09-29-2011, 09:15 AM
I think your best bet is to stop into ANY GM parts department, and have them pull up a picture of the door components on the screen......that way you get your number for sure...if it's the plastic part I think it is, shouldn't cost much......
96 Caprice Power Window Tract Guide Replacement Harlech61 Caprice 4 04-18-2010 07:20 AM
Rear Window Channel Guides/Rollers bocoogto Roadmaster 2 02-24-2010 11:31 PM
Window Guides Licklog Interior | Exterior | Appearance 0 03-30-2009 09:59 AM
94 Jimmy window sash clip fastener gs1344 Jimmy 1 05-20-2008 05:04 PM
question on window channel clips smokeyburnouts396 Nova 1 03-14-2006 05:38 PM
