Go Back   Automotive Forums Car Chat > Cars in General
Old 09-27-2011, 09:58 AM
GaryMinor GaryMinor is offline
Irregular (cupped) tire wear
I have a 2007 Honda Accord with 56K miles. The rear tires have about 16K miles on them and have become cupped on the inside edges. They were put on the back (new) and were not rotated until recently when the road noise increased to the point that I had them checked.
  • Alignment is good on all wheels
  • No obvious problem with bearings, brakes, shocks, etc.
  • The previous tires (same brand) were new with the car and lasted 40K miles on the back with no rotation and no problems.
Is there any history of the tires themselves being the cause of the problem? Does anyone have any suggestions?
I have cross rotated them to the front with the hope that the cupping will even out with additional miles. Is that reasonable?
Old 09-27-2011, 12:20 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Re: Irregular (cupped) tire wear
Probably a worn or possibly bent suspension component. Also, I would suggest rotating every 3,000 or 6,000 miles. If you have a bent or worn suspension component alignment will not fix the issue.
Old 09-29-2011, 10:24 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
I'll second the worn or damaged suspension scenario. Could be the struts, a worn out end link bushing. Visual checking is difficult...sometimes a road test with a chaser car is needed to see what is happening back there at speed. If it is the same wear on both left and right, then I'd be more suspect of a bad cross link component. Struts tend to fail one at a time.
The easiest, though not always reliable, is the bounce test where you push down on the rear of the car and see if the car rebounds without bouncing.
Next, look at the strut tube bodies for signs of oil leakage...oil stains, or collected oily dust.
Then check all the stabilizer links for bends and the bushings for end play. You've already mentioned the car's been tested for alignment, I'd also check for wheel bearing play and brake drag.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Odd wear on inside front drivers side tire tennesseeguy Sable 5 09-17-2011 01:38 PM
Tire wear overthehill10 Cars in General 1 05-21-2011 10:15 AM
olds 88 with uneven tire wear ryanusrey2012 Eighty Eight 1 05-09-2011 11:19 AM
510 irregular rear tire wear torp3do 510 0 10-14-2004 11:59 PM
Tire wear on the outside of both front tires burnsie629 Rodeo | Passport | MU 2 07-23-2004 02:45 PM
