Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > General
General news, articles, other.
Old 11-08-2001, 05:54 PM
Blue93G20 Blue93G20 is offline
ACT Clutch
Ok put in my ACT clutch and it engages really low on the pedal. I tryed to adjust it but it was already adjusted all the way out. Is this normal or what can i do to fix it? There is a lot of play in the pedal to where if i flick the pedal with my foot it rockets back out cause there is no resistance???
93.5 Infiniti G20
JDM SR20DE
Lowered on Intrax, Hotshot Header and Hotshot CAI
15.90@88MPH
http://community.webshots.com/album/34345621pASGoo
Old 11-08-2001, 06:13 PM
JD@af's Avatar
JD@af JD@af is offline
Missing in action
Send a message via ICQ to JD@af Send a message via AIM to JD@af
Did you get an ACT pressure plate or just the clutch? If not, and the ACT clutch is thinner than your previous unit, that could be the reason. Under those circumstances, as far as I know, there's not a whole lot you can do to fix the problem. Either get used to it, or get yourself a new clutch
Old 11-08-2001, 11:09 PM
JustinP10's Avatar
JustinP10 JustinP10 is offline
Send a message via ICQ to JustinP10 Send a message via AIM to JustinP10 Send a message via Yahoo to JustinP10
There is a fix... if you add a washer to your clutch cable, right where it kinda snaps into that bracket right up from the adjuster on the tranny, it will change the length of your cable (won't really, but it acts as though it does the same thing) and then you can adjust it from there. My clutch releases off the floor too, or did, until i put that washer in last week, now it's all better I think I may even have another washer laying around, but i did have to dremel out the inside for it to fit right, i can never find the perfect size anywhere. Oh well.
Justin McClanahan
95 G20
15.4 @ 91.4mph (2.4 60ft )
143.7whp and 131.4 ft.lbs
Primera (10:1) Intake Cam, HS CAI, HS Header, UR Pullies, 19* Timing, ACT, Lightened Stock Flywheel, GC/AGX, Pacesetter Short Shifter, and more stuff...
Old 11-09-2001, 01:08 AM
JD@af's Avatar
Missing in action
Cool JustinP10
Wow man, that's a great idea. That's really an awesome solution. I'll have to remember that one. Thanks :sun:
Old 11-09-2001, 01:10 AM
JustinP10's Avatar
Like everything else I'll try and write something up with pictures on how to do it, as it's kinda tough to explain, but very easy to do (or show with pictures). Once this week is over, i'll have a LOT more freetime to get some of those done. School sucks. 4 tests in one week, and that's after going to SEMA last week and missing all the classes. DOH! (It was worth it though, SEMA kicks ass!)
Justin McClanahan
95 G20
Old 11-09-2001, 06:25 AM
JD@af's Avatar
Missing in action
Arrow JustinP10
I'm curious... did you lighten your flywheel yourself?
If so, you're either very very good at working on your car or just flat-out crazy!!
Old 11-09-2001, 12:22 PM
JustinP10's Avatar
I had clutch specialties over in California do it. But most of your local machine shops can do the same. When I weighed it, it was about 13.5lbs when I got it back. Shipping weight was 21lbs. But that was in a box w/ the packing peanuts, my dumb ass forgot to weight just the flywheel. But i'd guess around 20-20.5lbs. I would highly recommend you NOT do this yourself... I little bit off on one side, and your whole drivetrain would probably get totally messed up
Justin McClanahan
95 G20
Old 11-12-2001, 05:07 PM
JD@af's Avatar
Missing in action
I've heard the horror stories of lightened flywheels breaking loose and flying through the air, with massive destructive force. Like breaking through the hood of the car without even slowing down, severing arms and other limbs, or outright killing people unlucky enough to be standing in the path of the rogue flywheels. Lightening your own flywheel is FUCKING DANGEROUS. Best leave it to professionals or else get yourself a professionally made lightened flywheel. Myself, I got a 9-pound aluminum "lightened" flywheel from ClutchMasters.
FS-ACT Clutch Kit 89-97 ST brianna Cars/Parts for Sale/Exchange 1 02-06-2002 02:00 PM
FS-ACT Clutch Kit 88-93 Truck brianna Cars/Parts for Sale/Exchange 1 02-06-2002 01:57 PM
ACT clutch dealers 91zc '71-'87 Civic | CRX 4 12-18-2001 09:19 AM
ACT Clutch Blue93G20 Engine 1 09-14-2001 05:55 PM
